CrossfireForum - The Chrysler Crossfire and SRT6 Resource (https://www.crossfireforum.org/forum/)
-   All Crossfires (https://www.crossfireforum.org/forum/all-crossfires/)
-   -   BCM clicking window won't go up (https://www.crossfireforum.org/forum/all-crossfires/81076-bcm-clicking-window-wont-go-up.html)
Mommasride Nov 16, 2019 01:18 PM
So my 05 Limited Roadsters passenger side window will not go up and I believe that the BCM body control module is the culprit. I have performed the service manual diagnostics, Its not the motor or the switch and I can make the window go up by reversing the polarity, I also swapped the right side switch with the drivers side and it works properly there. I have continuity from the switch to the BCM. When the switch is depressed for up I hear a clicking sound from the BCM. I have removed the BCM and cleaned, reseated, and inspected it. All wires going to the BCM seem to be attached well. When I put the BCM back in the window worked and went up and down for a second but then went back to fault. There are no other BCM control issues present other than this. So for whatever reason the BCM is not sending power to the motor for up function. I have scoured the forum for info but see nothing on a clicking BCM.
Has anybody experienced this issue?
Has anybody seen a lose solder connection in their BCM and repaired it?
I will try to find a used BCM and replace it. Does the replacement BCM auto program when installed or is there more to it?
Thanks
KeithTexas Nov 16, 2019 02:10 PM
Re: BCM clicking window won't go up
Sounds like you've done a thorough job diagnosing it. I'm in the middle of brewing some beer today...but I found this thread from 2013 on clicking BCM....I don't have time right now to read it all but it looks interesting. Any issues with the car alarm or locks not working?
Maybe this thread will help.
clicking BCM
Mommasride Nov 17, 2019 01:39 PM
Nice always wanted to try that. Thanks a lot of good info there. I got a used replacement BCM on the way so well see. Also thinking about a work around switch for the window.
KeithTexas Nov 19, 2019 08:36 AM
Sounds good. Please post a follow-up on the success you have with the BCM. The only other thing that I've found...and you've probably already seen it in the Service Manual:
"If the Body Control Module was replaced, turn the ignition on for 15 seconds (to allow the new BCM to learn VIN) or engine may not start."
You also may have to go through the reprogramming steps for the key fob in order for it to unlock/lock the doors....
Mommasride Nov 19, 2019 11:29 AM
Will do. I also found an outfit in Jacksonville, Module Experts, that will repair my BCM for $239.00.
g wheels Nov 19, 2019 03:46 PM
Please post the contact info for that outfit in Jacksonville. :)
Oh sorry, moduleexperts.com ..
SRQfun Nov 19, 2019 07:16 PM
Be wary of them. They were supposed to rebuild the bcm for our van and instead we got a used one that had close to 19,000 more miles. If you go with them make damned sure that it is very clear and in writing that they are not to substitute used parts and document everything including your mileage.
Mommasride Nov 21, 2019 11:05 AM
Update.
Received the replacement BCM same part# as the original A193 820 04 26.
The good, the window now goes up and down.
The bad, the rag top does not work.
I installed the BCM per the service manuals instructions gave it a good 30 seconds with key on for vin learning. Perhaps the replacement came from a coupe or maybe I need to give the key on learning process more time. Im $100 bucks into this at this point. I could send the original BCM out for repair at $250 more. While the BCM does at lot of things all its not doing is sending 12 volts to the window to make it go up, seems like a work around is possible because I can make the window go up by reversing the polarity at the motor? Further suggestions appreciated.
zip439 Nov 21, 2019 11:43 AM
Originally Posted by Mommasride (Post 932881)
Update.
On the BCM you will find additional numbers which are the specific hardware and software. Look at your used (the one that doesn't work correctly) ; the replacement should have those exact numbers. The part number A 193 820 04 26 may be correct for your convertible. I do not know. I have a coupe and my BCM is A193 820 00 26 I believe it is manufactured by Temix 00005357 model, on 04W24, Hardware code 46/02 and Software code 27/03. Perhaps somebody with better knowledge than I will help.
Ronman Nov 21, 2019 12:10 PM
Update.
Your best bet is to go to www.car-part.com and find a convertible like yours and get one with the same exact numbers as the one your car has. Try to make sure it has the same transmission, manual or automatic. It might take more than a few calls but hopefully will be worth it. Can't your return the one you bought?
Mommasride Nov 21, 2019 02:01 PM
Right, I tried the replacement again with a longer learn time with the same results.
My BCM nos. are part no. A193 820 04 26 (07)
TEMIC 00005357 04W32 HW:36/03 SW:44/03 5357U4HO4B64 which I assume is a SN.
The replacement is A193 820 04 26 (07) TEMIC 00005357 05W11
HW:47/03 SW:44/03 5357U5C16A27
So the hardware and maybe the date are different.
I'll see about my return options and continue to search for another BCM. A nearby junk yard has one with all numbers matching except the date for $104 but a 20% restock fee if it doesn't work. I may try that.
Mommasride Nov 29, 2019 04:27 PM
Update.
Problem solved. Received another BCM and the window and the top are functional. Other BCM controlled functions seem to be ok. Time will tell. Once again the info on this forum saved me. Thanks.
© 2026 MH Sub I, LLC dba Internet Brands
