Note to new owners
Old Nov 17, 2021 | 01:29 PM
Default Note to new owners
This suggestion goes back almost to the beginning of this forum. The two most common reasons for problem starting are failures of the RCM (relay control module) and the CPS (crank position sensor). It is recommendid to keep a spare of these two items in your trunk just in case. The RCM is plug and play and takes 5 minutes. The CPS requires a small ratchet, extension and an E8 female torx socket. It would be smart to keep these with you also. This can keep you from being stranded. If you ever need to replace the RCM, keep the old one and have it rebuilt by djtighe@hotmail.com and keep it as a spare. The correct email in tighed1@hotmail.com
Lots of info here.
Old Nov 17, 2021 | 01:55 PM
Default Re: Note to new owners
Bump
Old Nov 17, 2021 | 05:42 PM
Originally Posted by ZERACER
This suggestion goes back almost to the beginning of this forum. The two most common reasons for problem starting are failures of the RCM (relay control module) and the CPS (crank position sensor). It is recommendid to keep a spare of these two items in your trunk just in case. The RCM is plug and play and takes 5 minutes. The CPS requires a small ratchet, extension and an E8 torx bit. It would be smart to keep these with you also. This can keep you from being stranded. If you ever need to replace the RCM, keep the old one and have it rebuilt by djtighe@hotmail.com and keep it as a spare.
Lots of info here.
Help me out here, isn't it a T-8 SOCKET? Didn't remember it being a T-8 bit. Oldtimers here???
Old Nov 17, 2021 | 06:01 PM
You are correct, my miss statement. It is a female E8 torx socket. Thanks for the catch.
Old Nov 17, 2021 | 07:44 PM
The correct address is tighed1@hotmail.com
Old Nov 18, 2021 | 11:40 AM
Yeah, thanks! I went out to my car later on and found my drive/extension/socket (with the NEW Bosch sensor) confirming it was a socket. Thanks for replying!
Old Nov 18, 2021 | 06:46 PM
Deepsea21's Avatar
Yeah, and if you're gonna own one of these with Mercedes under the hood may as well get the whole Torx M/F set. I know I did. Note: To use this full set you're gonna need 1/4", 3/8" and 1/2" drives.
Old Nov 24, 2021 | 10:50 PM
pjpalmeri's Avatar
Had the RCM replaced in my 2005 LE in September 2018. Already went bad and now have to get another new one. Hope I get more than 3 years out of this next one
Old Nov 24, 2021 | 11:23 PM
exparamedic's Avatar
Do you remember what brand and where you bought it?
I was going to buy one for a spare and may want to avoid your problem.
Any recommendations out there?
Old Nov 25, 2021 | 08:31 AM
pjpalmeri's Avatar
The new RCM was installed by my local Auto repair shop that specializes in foreign cars.
The RCM has a Mercedes Benz logo on it so I am assuming he purchased it through a reputable MB authorized parts store.
I am going to ask him where he purchased the new one he is installing so I can obtain a backup as well.
Once that one goes, I'll probably sell the beast.
Old Nov 25, 2021 | 09:54 AM
Thanks for the information.
Jim
JBRDH
Oct 9, 2021 10:10 AM
sgnorris
May 4, 2021 11:56 AM
Trey05-6101
Nov 11, 2020 10:54 AM
jeffreyt
U.K.
Nov 24, 2018 09:33 AM
Billy22Bob
Sep 8, 2015 02:57 AM
