Source for roadster antenna / base / rubber gasket
Old Nov 15, 2022 | 01:22 PM
Bayukbros's Avatar
Smile Source for roadster antenna / base / rubber gasket
Can someone direct me to a source for the OE antenna mast AND the rubber gasket for the base; this belongs to a 2006 Roadster and is on the rear driver's side top fender .. much appreciated .. thanks bayukbros in RDU
Old Nov 15, 2022 | 07:36 PM
Default Re: Source for roadster antenna / base / rubber gasket
Try this website: CLICK
Lots of sources for MAST & BASE GASKET.
PS: Wife & I lived in Durham for 11 years before moving to SC.
Old Nov 16, 2022 | 12:55 AM
UrbanE's Avatar
I’ve read somewhere that the base for the roadster antenna is similar (possibly same) on many VW passenger cars. Might be worth a quick trip to the pick and pull yard.
I grabbed one at my last stop at the parts yard. Haven’t needed to install one yet.
tossed it into the parts box
Old Nov 16, 2022 | 09:36 AM
Bayukbros's Avatar
Thank you .. found it ...
Old Nov 16, 2022 | 11:56 AM
stlouistrucker's Avatar
This past summer I purchased the Base Gasket on eBay that dedwards0323 provided the link. It fit and worked perfectly. Unlike others on the forum, I removed the antenna completely so that I could remove the entire old gasket. The old gasket on my Crossfire was not just a ring like the new gasket. It pretty much covered the whole area under the base except for the hole in the fender. The hardest part was aligning the gasket to the bottom of the base and keeping it in place until tightened down. I removed the side panel in the trunk to make it easier. That also gave me the opportunity to check the level of the top cylinder's hydraulic fluid reservoir. I used a deep well socket to remove and tighten the nut on the bottom of the antenna. I think it was a 22mm, but not sure. It took me about 45 minutes from start to finish. I didn't hurry and even waxed the fender under the base while it was off.
Old Nov 16, 2022 | 12:02 PM
Bayukbros's Avatar
Thank you, good information .. and to all that replied ... bayukbros in RDU
Old Nov 21, 2022 | 07:20 PM
hot57rambler's Avatar
I got my mast and base on Amazon.
awilson40
Jul 13, 2019 04:41 PM
Shamrock
Oct 27, 2016 09:30 PM
JustUKEin
Jul 17, 2014 06:23 PM
xfire17
Oct 30, 2013 12:39 AM
