Radios Question
Old May 11, 2006 | 10:34 AM
Cissy's Avatar
Default Radios Question
Are the pin connectors pretty standard? I mean, if I were to find another audio unit I liked better than the OEM, would it, in general, be a problem with connecting it? Or, does one have to modify in order for the antenna lead and/or pin connection to fit?
Shouldn't I be able to just slide in another unit and connect as I do the OEM?
Just curious, thanks!
~Cissy
Old May 11, 2006 | 07:08 PM
former NXMX5's Avatar
Default Re: Radios Question
you'll need a Scosche VW01 wiring adapter (free if you order from www.crutchfield.com or www.sounddomain.com) and a Metra 40-EU10 antenna adapter (Best Buy, Circuit City, $15) to install a new head unit.
Old May 11, 2006 | 07:09 PM
Cissy's Avatar
Great! thanks so much for detailed answer. I'll save it for future.
Old May 11, 2006 | 08:05 PM
crossfirefrank's Avatar
Smile Re: Radios Question
I upgraded mine a couple weeks ago it was very easy to do but you will need to change to wires around on the connector to make the new head unit work properly. Basically you need to reverse the constant 12 volt power wire and the switched 12 volt wire. E-mail me at: frank-hasbrouck@peoplepc.com for more info. I put in a sony head unit and changer that sound 100% better than the stock.
Old May 11, 2006 | 08:15 PM
Cissy's Avatar
Originally Posted by crossfirefrank
I upgraded mine a couple weeks ago it was very easy to do but you will need to change to wires around on the connector to make the new head unit work properly. Basically you need to reverse the constant 12volt power wire and the switched 12 volt wire. e-mail me at frank-hasbrouck@peoplepc.com for more info. I put in a sony head unit and changer that sound 100% better than the stock.
Thanks, Frank! I don't have a replacement in mind, but in the future, if I want to change out my OEM unit for a better one, I shall save your information.
Thanks!
smokey847
Nov 12, 2015 11:54 PM
jimf
Oct 10, 2015 10:22 AM
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
Selbyl
Sep 26, 2015 04:15 AM
rmcdaniel12
Sep 21, 2015 10:58 AM
