Wheels I picked out, will they fit
Here are rims I picked out for my 04' Coupe. Looks like they will fit, but I wanted to check with everyone here first.
Here are the 18's for the front:
http://www.discounttiredirect.com/di...08505&bp=5-100
Here are the 19's for the back:
Thank you in advance for any help.
Re: Wheels I picked out, will they fit
the back will need a spacer to make it look correct but they will fit...
just a tip for when you go to put them on... when you take your stock wheels off, put the wheel bolt in the wheel and measure how much thread is exposed on the back side of the wheel... when you go to put on your new wheels, make sure you put the wheel bolt in it before you put it on... and measure to make sure there is not more thread exposed than with the stock wheels... damage from the bolts being inserted too deep can be extensive...
MAXIMUM
08-04-2015 11:04 PM
tom2112
07-28-2015 08:12 AM
