TSBs and service bulletins retrieved for 2005 Xfires - NHTSA
Old Jul 10, 2006 | 10:24 PM
cudaman's Avatar
Default TSBs and service bulletins retrieved for 2005 Xfires - NHTSA
Go to the service bulletin part of the NHTSA and you will pull up the following for 2005's. Didn't run 2004's. Formatting gets screwed up here. Looks much better at nhtsa.gov site.
http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm
Make : CHRYSLER
Model : CROSSFIRE
Year : 2005
Manufacturer : DAIMLERCHRYSLER CORPORATION
Service Bulletin Num : 0800306
Date of Bulletin: JAN 18, 2006
NHTSA Item Number: 10019250
Component: ELECTRICAL SYSTEM
Summary:
INSTRUMENT CLUSTER INITIALIZATION. *TT Check to Request Research. Submit below.
Make : CHRYSLER
Model : CROSSFIRE
Year : 2005
Service Bulletin Num : 19
Date of Bulletin: JAN 01, 2006
NHTSA Item Number: 10019269
Component: ENGINE AND ENGINE COOLING:
COOLING SYSTEM:FANSummary:
THE RADIATOR COOLING FAN MOTOR MAY HAVE BEEN IMPROPERLY ASSEMBLED. CUSTOMER SATISFACTION NOTIFICATION E19 RADIATOR COOLING FAN MODULE. *TT Check to Request Research. Submit below.
Make : CHRYSLER
Model : CROSSFIRE
Year : 2005
Service Bulletin Num : 2100205
Date of Bulletin: MAY 07, 2005
NHTSA Item Number: 10012339
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
TRANSMISSION FLUID MAY BE WICKING IN THE RIGHT FRONT CORNER OF THE TRANSMISSION OIL PAN AREA. *EH Check to Request Research. Submit below.
Make : CHRYSLER
Model : CROSSFIRE
Year : 2005
Service Bulletin Num : 2100204
Date of Bulletin: FEB 05, 2005
NHTSA Item Number: 10006447
Component: POWER TRAIN:MANUAL TRANSMISSION
Summary:
FIRST GEAR SYNCHRONIZER ENHANCEMENTS. *TT Check to Request Research. Submit below.
Make : CHRYSLER
Model : CROSSFIRE
Year : 2005
Service Bulletin Num : 0800905
NHTSA Item Number: 10012804
Summary:
PNEUMATIC LOCK HOSE REPAIR KIT AVAILABLE. *TT Check to Request Research. Submit below.
Make : CHRYSLER
Model : CROSSFIRE
Year : 2005
Service Bulletin Num : 2300405
Date of Bulletin: JAN 28, 2005
NHTSA Item Number: 10012257
Component: STRUCTURE:BODY
Summary:
DOOR GLASS MISALIGNMENT OR CONTACTS THE ROOF. *TT Check to Request Research. Submit below.
Make : CHRYSLER
Model : CROSSFIRE
Year : 2005
Service Bulletin Num : 0800205
Date of Bulletin: JAN 13, 2005
NHTSA Item Number: 10012333
Summary:
HEADLAMP CONDENSATION. *EH Check to Request Research. Submit below.
Make : CHRYSLER
Model : CROSSFIRE
Year : 2005
Service Bulletin Num : 2100105
Date of Bulletin: JAN 06, 2005
NHTSA Item Number: 10012316
Summary:
GEAR GRIND LIKE SOUND WHILE SHIFTING. *EH Check to Request Research. Submit below.
Make : CHRYSLER
Model : CROSSFIRE
Year : 2005
Service Bulletin Num : 0804304
Date of Bulletin: DEC 18, 2004
NHTSA Item Number: 10011926 C
omponent: EXTERIOR LIGHTING:HEADLIGHTS
Summary:
HEADLAMP CONDENSATION. *TT Check to Request Research. Submit below.
Make : CHRYSLER
Model : CROSSFIRE
Year : 2005
Service Bulletin Num : 0200904
Date of Bulletin: DEC 16, 2004
NHTSA Item Number: 10011939
Component: SUSPENSION
Summary:
SQUEAKING SOUND FROM FRONT SUSPENSION. *TT Check to Request Research. Submit below.
Make : CHRYSLER
Model : CROSSFIRE
Year : 2005
Service Bulletin Num : 2305104
Date of Bulletin: DEC 06, 2004
NHTSA Item Number: 10011938
Summary:
LIFTGATE BUMPER FASTENER WILL NOT TIGHTEN. *TT Check to Request Research. Submit below.
Make : CHRYSLER
Model : CROSSFIRE
Year : 2005
Service Bulletin Num : 0200804
Date of Bulletin: NOV 08, 2004
NHTSA Item Number: 10011548
Summary:
RATTLE SOUND FROM REAR. *TT Check to Request Research. Submit below.
Make : CHRYSLER
Model : CROSSFIRE
Year : 2005
Service Bulletin Num : 2304203
Date of Bulletin: OCT 18, 2004
NHTSA Item Number: 10010532
Summary:
DECKLID WILL NOT OPEN. *EH Check to Request Research. Submit below.
Make : CHRYSLER
Model : CROSSFIRE
Year : 2005
Service Bulletin Num : 0803004
Date of Bulletin: SEP 02, 2004
NHTSA Item Number: 10010480
Summary:
ONE OR BOTH KEYLESS ENTRY TRANSMITTER DO NOT WORK. *TT Check to Request Research. Submit below
Old Jul 14, 2006 | 12:10 AM
FirebaseD's Avatar
Default Re: TSBs and service bulletins retrieved for 2005 Xfires - NHTSA
Great find Brother... hooah
Old Jul 14, 2006 | 09:11 AM
CrossfireLTD's Avatar
Cool Re: TSBs and service bulletins retrieved for 2005 Xfires - NHTSA
You can also look here:
https://www.crossfireforum.org/forum...&highlight=TSB
xfClifford
Mar 3, 2021 04:52 PM
Wes__Hutchinson
Jun 10, 2019 11:24 AM
itsky
Aug 4, 2015 10:35 PM
itsky
Aug 1, 2015 03:45 PM
Rusty475
Jul 13, 2015 10:03 AM
