Radio Head Unit Prewired?
Old Nov 27, 2006 | 05:15 PM
Default Radio Head Unit Prewired?
Does anyone know if the XF OEM radio head unit w/NAV is prewired for an CD changer or such equipment in the trunk?
Old Nov 27, 2006 | 06:13 PM
blacklimitedcoupe's Avatar
Default Re: Radio Head Unit Prewired?
FPM - I just installed factory NAV in my car, and I read the manual which states that you can add a CD changer to the headunit. I'm not sure how that works, but it says you can... If you find out, let me know.
Old Nov 27, 2006 | 06:16 PM
I'm planning on installing the Phatbox and it uses the same plug and wire you would normally have for the CD changer. If the wire is preinstalled at the factory, all I have to do is plug-and-play, otherwise I have to run the cable from the head unit to my trunk.
Old Nov 27, 2006 | 06:20 PM
What is a "PHATBOX"? And does the CD changer plug into that empty slot on the back of the headunit above the factory harness plug?
Old Nov 27, 2006 | 06:24 PM
It might be easier if you follow this thread, but think of it as a ipod for your car. You can store all your library of music. The come in 20 -128 GB drives, and software to manage all you music, all controlled by your head unit.
https://www.crossfireforum.org/forum...801#post104801
Old Nov 27, 2006 | 10:11 PM
stryfox's Avatar
There is no wire running from the factory headunit to rear cargo area for a changer.
The port would be on the back of the head unit.
If you install a CD changer you must run the wire yourself.
Just so you know The changer comes with the wire, not the headunit.
Make sure the one you want is compatible before you buy.
Old Nov 27, 2006 | 10:23 PM
MMZ_TimeLord's Avatar
I have installed a Becker 6-Disc changer and ran the cable myself. It fits nicely in the 'first aid recess' under the cargo area. Only 'mod' I had to do was deepen the hole itself and pad it with soft foam.
Running the cable was a chore, but can easily be routed next to the existing wiring along the passenger side floor, out the front of the carpet and then into the dash to the center for the head unit. Make sure you get the 20' or 25' connection cable.
Cheers!
Old Nov 28, 2006 | 09:17 AM
Cheers!
Could you give me the part number and price of the CD changer? I just installed factory nav and I want a CD changer so I can leave the nav disc in the headunit. Did it plug into the empty slot on the back of the headunit above the factory harness plug? Thank you.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Sterling57
Apr 11, 2016 06:11 PM
crossfireE
Oct 2, 2015 01:40 AM
brandoni
Sep 30, 2015 07:48 PM
Selbyl
Sep 26, 2015 04:15 AM
