HID Help
Old Oct 6, 2007 | 11:55 AM
LantanaTX's Avatar
Default HID Help
I am installing HID's right now and the kit I have says that you must hook up the red wire to the positive terminal on the original connector and the black to the negative or burn out the system... makes sense... On the original two pin connector the wires are all black. Any idea which is positive?
Old Oct 6, 2007 | 03:41 PM
LantanaTX's Avatar
Default Re: HID Help
Never mind... After reading about 17 threads I found the answer. Two black equals ground. The HID's are awesome! First side was 1.5 hours of $%$&^(*&$%!!! because I removed the spring clip. Second side took 10 minutes.
Old Oct 6, 2007 | 06:21 PM
intenseblu's Avatar
yup ... just did that myself so had the answer for ya but darn got to it before i could tip ya.
best way to find out in future, 5 dollar test light from any auto place. turn on the headlight switch and attach the clip to ground and use test light probe to check each bulb socket pin. the one that lights is positive.
PS ... lantana from your previous posts i know you know this but for people newer to the hobby thought i'd put it there for them.
Old Oct 6, 2007 | 06:52 PM
LantanaTX's Avatar
I have the test light that takes a single AA battery, but couldn't find it anywhere which usually means my son has been in the tool box again... I hooked up two wires to the halogen bulb I removed and tried to make a test light out of it but this didn't work either. I was able to finally find the answer in the forum when I searched for "HID Negative". BTW, I wrote up a small review of the kit I used if anyone is interested it is in the exterior lighting section.
xfireohio
Jul 20, 2020 12:03 AM
Adrian_X
Nov 9, 2017 08:49 AM
RojoGTO
Feb 6, 2016 11:14 AM
gp1200x
Dec 6, 2015 12:59 PM
AlbertFattal
Sep 24, 2015 05:03 AM
