Spring Kit
Old Nov 17, 2007 | 07:26 AM
Panzer1's Avatar
Default Spring Kit
Anyone know if these will work on ours...
Schatz Lowering Springs for SLK230 and SLK320 #1702020
Lowers your SLK between 30mm-35mm (1.1" - 1.3") front and rear for improved handling and a great look High Quality. Made in Germany.
$229.99 for all 4.
Old Nov 17, 2007 | 10:09 AM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Spring Kit
the slk 320 springs will work on the crossfire... this is what i had on my car (but eibach)...
they will be a tad lower than the crossfire designated lowering springs.
Old Nov 17, 2007 | 08:56 PM
Panzer1's Avatar
Thanks Andrew.
I figure I wasn't able to sell it while I was away the past 2 yrs so I guess Il'l keep it and start doing some mods...
BTW I'll be back for good in feb, still need those emblems... Thanks.
Old Nov 18, 2007 | 09:22 AM
Maxwell's Avatar
save yourself about $300 and cut out 1 or 3/4 of a coil, has the same effect. https://www.crossfireforum.org/forum...ad.php?t=18650
and another good write up by Bazzle on benzworld http://www.benzworld.org/forums/r170...val-front.html
this tool makes life easier, you might want to rent it from the dealer.
Old Nov 18, 2007 | 08:48 PM
Panzer1's Avatar
Hmm ? I was always told that cutting or heating springs create long term damage to the springs ?
Anyone has cut theirs here ?
How about the shocks ? Any shocks in particular, somehting tells me those would have to be change as I change the springs...
Good thought, spring compressor...
Old Nov 19, 2007 | 08:07 AM
Maxwell's Avatar
you never heat springs, that's a total amatuer move. cutting is OK,
As for shocks I would use an adjustable sport shock.
smfrycruzr
Jul 17, 2023 05:33 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ayebb
Sep 18, 2015 03:35 PM
Big Daddy
Sep 10, 2015 10:21 PM
