Location / Running wires for new Amp / Sub
Old Jan 29, 2008 | 01:25 PM
nox1s's Avatar
Default Location / Running wires for new Amp / Sub
Hi,
I decided to put an Alpine M450 Amp http://www.crutchfield.com/App/Produ...0&i=500MRPM450 and an Infinity Reference http://www.crutchfield.com/App/Produ...nce&i=1081050W Sub in my car.
I was thinking about where exactly to put the Amp / Sub. Has anyone successfully ran the wires to the trunk hiding them decently? I was looking and I don't know how I would get the wires from the front over the wall in the middle to the trunk without exposing them. Is there something I can remove that will let me pass through.. ??
Also, would it be a bad idea / impossible to tap into the line powering the stock amp and running a cable powering another amp from that one?
Thanks in advance!
Old Jan 29, 2008 | 06:54 PM
maxcichon's Avatar
Default Re: Location / Running wires for new Amp / Sub
Not with a "2X20 amp" fuse ratiing! I think it best to run a dedicated line for a large-draw add on like this amp.
Old Jan 29, 2008 | 07:18 PM
nox1s's Avatar
Figured i'd at least ask and try to see anyways
Any idea about running the wires to the trunk though? I guess I could just make them as stealthy as possible and just have them peaking out to go over the big wall..
Old Jun 27, 2008 | 02:40 PM
smokey847's Avatar
Nox,
Did you ever go through with this setup? If so, do you have any photos of it you can share?
Old Jun 27, 2008 | 08:30 PM
nox1s's Avatar
Originally Posted by smokey847
Nox,
Yeah, I did. I don't have any pictures right now.. and unfortunately I am going up north a one and a half weeks.. I can get you some after then...
basically, search for the grommet under the battery tray.. another thread someone posted on how to access that.. that's to run the wire -> inside of the cabin..
after that, it isn't that bad. just lift up the carpet on the side (this is where I ran my RCA / power cables.. i had to remove the door sill and one of the side panels)
there's a spot to go to the trunk.. you need to take off those black clips.. they look like they are permanent but take a pair of pliers and get them out.. i mangled a few that I need to replace..
with pictures it'll be easier, but yeah. that's the general idea
Old Mar 13, 2009 | 09:05 AM
SOunds good, but I have been searching for weeks and found no pics on exactly how anyone ran their power, RCAs, etc. So if you would be kind enough, it would really help me out as I will be installing this weekend. THANKS.
Old Mar 13, 2009 | 05:57 PM
BLKFIN's Avatar
ADDICTED TO BOOST
Take out the battery and remove the battery tray. The grommet has several "nipples" molded in so that you can just clip one off and push the cable through, See some photos to this gallery. It is actually pretty easy and no need for the DRILL!!!
https://www.crossfireforum.org/galler...00/ppuser/4465
Old Mar 13, 2009 | 08:03 PM
robs 04 crossfire's Avatar
Hello i have a nice set up in mine i will try to get pics tom if you still need them it is clean and all the wires are hidden. Also i am new to this forum so hello to everyone.
Old Mar 15, 2009 | 09:02 AM
BLKFIN's Avatar
ADDICTED TO BOOST
Welcome! Be sure to post up those pictures~
xfClifford
Mar 3, 2021 04:52 PM
gp1200x
Dec 6, 2015 12:59 PM
BrenLW
Aug 5, 2015 04:53 AM
pioneer4x4
Jul 27, 2015 02:04 PM
axnguyen
Jul 21, 2015 11:41 AM
