How far should the key FOB reach?
Old May 11, 2008 | 06:26 AM
smokey847's Avatar
Default How far should the key FOB reach?
I was walking out from the mall yesterday and wanted to test out how far the key FOB would reach from. I tested with the panic button since there is no audible notification when you lock/unlock. It didn't work until I was less than 25 or 30 ft. from the car.
Is this normal?
How long is it supposed to reach? Thanks!
Old May 11, 2008 | 06:49 AM
maxcichon's Avatar
Default Re: How far should the key FOB reach?
When I replaced the fob batteries, it would work at ~40'-50'.
Old May 11, 2008 | 06:51 AM
Is this normal?
When you're only 15 the range is only about 25ft. It gets longer the older you get. When you're my age I can reach it from China
Old May 11, 2008 | 10:25 AM
smokey847's Avatar
Lol. Also, what is the purpose of the littled red thing at the top?
Old May 11, 2008 | 11:57 AM
nox1s's Avatar
It's the transmitter.
Old May 11, 2008 | 12:32 PM
chuck65's Avatar
On top of FP or the fob.
Old May 14, 2008 | 12:07 PM
Sinners's Avatar
Holding the fob under your chin will allow it to go as far as 100 feet. I do it on our dealership lot all the time. Also, the signal for panic will travel farther than unlock/lock will
Old May 14, 2008 | 03:19 PM
smokey847's Avatar
Huh?
My panic button only worked from about 30 feet away. Do you think a battery replacement would do the trick?
Old May 16, 2008 | 10:12 AM
Sinners's Avatar
Well Im not sure. I think it has to do with line of site, the way your car is facing, and the battery life. I just know t hat if I put the fob under my chin I am able to set of the alarm from my desk and my car is accross the parking lot, accross the street and then through another lot.
Old May 16, 2008 | 10:37 AM
mrphotoman's Avatar
If you pull down your pants and stick it in your butt crack it will transmit up to 150' from your car. Give it a try!
Old May 16, 2008 | 11:25 AM
rcompart's Avatar
Just make sure you don't hit the key release button before you do or it may be quite painful with the key sticking out! Don't ask me how I know this.
Old May 16, 2008 | 11:34 AM
mrphotoman's Avatar
The shape of your butt acts like a parabolic dish which results in a greatly increased range.
As for the key release button, some are rumored to enjoy the experience!
fastfred
Nov 5, 2018 09:47 AM
o55ie18
Oct 5, 2015 05:50 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Padgett
Southeast Forum
Sep 27, 2015 09:37 AM
xjken
Sep 13, 2015 10:18 PM
