Rolling Start?
Old May 15, 2008 | 11:31 AM
shubi.s's Avatar
Default Rolling Start?
The battery on my '06 base coupe died last week. I was able to jump start it last friday night, and I let it run for about half an hour. I went to start it on Sunday and it just wouldn't start and every single light on the dash came and stayed on until the battery completely drained out. I called the local chrysler dealer (which I did not purchase it from) and they said it would have to be taken to their other branch, 45 miles away. Getting to the point, is it possible to do a rolling start with our cars? If so, will it damage the car in anyway?
Old May 15, 2008 | 12:36 PM
spensley's Avatar
Default Re: Rolling Start?
Go for it.
It won't harm anything.
I suggest you start it in 2nd gear.
Or, get some jumper cables.
Old May 15, 2008 | 12:47 PM
MikeL38's Avatar
I had the same problem with my 06 roadster, my battery was almost empty. I added water and recharged with the cables off the battery. I have not had any problems since. I suggest you check the fluid level in the battery, be careful when you do this it is acid and will explode if a spark is created when the caps are off!! Good Luck
Old May 15, 2008 | 12:50 PM
shubi.s's Avatar
What sort of water should I use? distilled, or is there a specific solution that I should use
Old May 15, 2008 | 12:54 PM
MikeL38's Avatar
They recommend distilled water, but I used tap water, it will work just fine. If you can get distilled water use it.
Old May 15, 2008 | 12:55 PM
spensley's Avatar
If you can't get distilled, boil your own tap water.
Old May 17, 2008 | 09:14 AM
shubi.s's Avatar
how high should the water level be? also, do I put water into just one of the caps, or should I unscrew all of them and put water in individually?
Thanks everyone, I really appreciate the help
Old May 28, 2008 | 12:28 AM
Mimi05SRT6's Avatar
Unsrew and fill all of them.
pioneer4x4
Aug 1, 2018 09:58 AM
jhansen
21
Feb 15, 2017 04:26 PM
velociabstract
28
Oct 28, 2015 12:46 PM
James1549
Crossfire Events and Meets
Aug 27, 2015 08:37 AM
x1xsinisterx1x
Aug 24, 2015 07:31 PM
