Headlights look foggy (dirty)
Old Jun 6, 2008 | 12:30 PM
rodimus's Avatar
Default Headlights look foggy (dirty)
QUESTION-
I recently aquired a SRT6, a the headlights seem dirty or foggy on top, is this a common problem??
Should I bring this to the dealer attention?
THANKS IN ADVANCE!!
Old Jun 6, 2008 | 12:51 PM
chuck65's Avatar
Default Re: Headlights look foggy (dirty)
Originally Posted by rodimus
QUESTION-
THANKS IN ADVANCE!!
First you have to determine if your headlights have moisture inside or if the outside is hazy and in need of polishing. I used 3M Plastic Polish on mine and it did a great job.
Be sure and try our search feature in the future. It's a great tool. Try this post:
https://www.crossfireforum.org/forum...azy+headlights
Good Luck, let us know how you make out.
Old Jun 6, 2008 | 01:02 PM
rodimus's Avatar
Thanks for the tip. Just getting used to the endless information on this forum, it's amazing!!
I would I tell if it's on the inside?? I'm not to auto savvy so bare with me if that is a dumb question. That thread you directed to me to is great. If I can't clean it off, I guess it's back to the dealer I go.
THANKS AGAIN!!
Old Jun 6, 2008 | 01:28 PM
Airscape's Avatar
THANKS AGAIN!!
I think i have a combo of inside and outside. I would say the easiest way for me to tell was to just wipe my finger across the haze. If it fades and comes back right away its on the outside, if not it's either reallllly caked on or on the inside. The haze has an almost purple-blue color also.
Old Jun 6, 2008 | 01:56 PM
RPM's Avatar
RPM
Moderator
This topic comes up a lot.
There is an issue with the Crossfire headlights and there is a dealer TSB for them if you are under warranty.
Old Jun 9, 2008 | 11:35 AM
rodimus's Avatar
Brought the car in with the TSB and they ordered the parts, sight unseen. I was pretty happy, hopefully this does the trick. THANKS!!
Old Jun 9, 2008 | 12:26 PM
HyprLtH20's Avatar
www.CustomCrossfire.com
sand them down really well with some super fine sand paper.. maybe a 1000 or 2000 grit. then get maguiars plastic X and buff them out with that. works like a charm and looks brand new!. be sure not to get it on the paint though!
Old Jun 9, 2008 | 08:46 PM
MAYAman's Avatar
^^^Great tip thanks, my right headlight is turning brown and I don't know why!
Old Jun 12, 2008 | 05:22 PM
kurtisberry's Avatar
If it is on the outside and still under warranty, the dealer should replace the headlights. Had mine replaced with two weeks left on the warranty for free. The TBS only deals with water moisture on the inside.
Old Jun 27, 2008 | 01:55 PM
rodimus's Avatar
You were right!!
They did the TSB and it did nothing.... They just replaced the headlights, and they look great.
Are these a new version, will they have the same problem??
Old Jul 14, 2008 | 09:15 PM
Realiztik1's Avatar
Thanks for all the tips...This sounds really helpful...and to think i was ACTUALLY trying to buy new headlights all together!!!!!! I have this "HAZE" on both lamps very bad.....makes me feel like my baby's sick or something lol
Old Jul 15, 2008 | 03:34 AM
04xfirecoupe's Avatar
I think I use something called Plast-X, I got it at Advanced Auto and it works like a charm for the exact same issue. Think it was something like 5 bucks, well worth it!
Old Aug 2, 2008 | 02:52 PM
ohnoesaz's Avatar
I polished and polished with "Scratch Out", common stuff found at any regular store, like walmart. I don't know if I'd say they're good as new, but they definately look very fancy again.
Old Aug 2, 2008 | 03:00 PM
bigbengt67's Avatar
Funny this thread came back today. I just did my headlights with the Meguiar's PlastX. I bought it at WalMart for about 5 bucks. I spent about 10 minutes on each headlight applying the PlastX using a wax applicator. It works well for removing the haze at the top of the lights, but understandably doesn't do much for the small rock chips and deeper scratches in the lens. Overall I'm happy with the results! I'll probably do this each time I wax my car (which I also did today).
Old Aug 2, 2008 | 04:49 PM
TheDon's Avatar
Check out my thread if you're looking for perfection:
https://www.crossfireforum.org/forum...ad.php?t=26589
Old Sep 22, 2008 | 05:41 PM
ggguy's Avatar
Just found out that haze on headlight was covered on my 05 roadster. Local dealer said they will be replaced under warrantee. This site probably saved me alot of money because I had no idea they would be covered and was suprized with dealers answer.
Old Nov 3, 2008 | 07:42 PM
Kit Fox's Avatar
Ya I'm not under waranty anymore, and I think its on the inside, I can't tell.
Old Nov 8, 2008 | 07:22 AM
oceans2c's Avatar
I wish I had documented my recent experience with this...But there is a product made by Crystal view chemicals inc. go to: myheadlight.com I have an 05 and dealer refused to replace mine. So I procrastinated. My lenses were actually pitted in some spots with a yellow sun damage.
I bought this little kit and I was shocked at the results (15 bucks) I ahd ordered new lenses and cancelled.
If nothing else save those old lenses for experimental product testing.
Old Nov 8, 2008 | 08:18 AM
makeithappen's Avatar
when first got my car i complained and the dealer went in and it looked like they took a wire brush to it or something which got the fogy out but just scratched it and now a year later its worse then it originally was. i am going to get this headlight stuff that a friend that works at advanced auto told me to grab and it has a lifetime guarantee.
Old Nov 8, 2008 | 10:24 AM
oceans2c's Avatar
Good luck and let me know. Everylittle bit helps. Nice color on that crossfire. I don't see many like that.
