Dyno mode on SRT6/SLK32 ?
Old Oct 25, 2008 | 02:09 PM
Guran's Avatar
Default Dyno mode on SRT6/SLK32 ?
How do i dyno my car ?
Is there any Dynomode that i can use
on a SRT6/SLK32. If, how ?
/Göran
Old Oct 25, 2008 | 04:52 PM
TVT_DESIGN
Guest
Posts: n/a
Default Re: Dyno mode on SRT6/SLK32 ?
SLK32 should be able to, so I've heard.
SRT6 needs to have the front wheels spinning.
Old Oct 25, 2008 | 05:27 PM
Lotus F1's Avatar
I believe you to pull breakers 17 & 18 Drivers Side and do Dyno pull in 4th gear.
Old Oct 25, 2008 | 05:53 PM
lowwkeyy's Avatar
go to the radio controls up,up,down,down,B,A,B,A START and you should be good to go
lowwkeyy's Avatar
the above post was a joke just incase your about to try it
Old Oct 25, 2008 | 06:19 PM
TVT_DESIGN
Guest
Posts: n/a
Good Ole' Konami.
That code is the only way to beat Contra without killing yourself.
Pulling the fuses will still not result in a 6000 RPM run.
Old Oct 25, 2008 | 07:04 PM
BLKFIN's Avatar
ADDICTED TO BOOST
Originally Posted by TVT_DESIGN
Good Ole' Konami.
Pulling fuses 17 and 18 and a Jerry ECU Tune will result in a 6000 rpm run! Without the tune you are correct, it will not.
Old Oct 25, 2008 | 08:27 PM
BrianBrave's Avatar
<--- Huge Horsepower
My SRT6 can load up on any dyno, keep the front wheels stationary the whole time, never pull a fuse, and bust a run to 6,200 RPM - Every Time...
Old Oct 26, 2008 | 01:56 AM
Guran's Avatar
It didn´t work
I´m going to contact AMG and ask if they know
/Göran
Old Oct 26, 2008 | 06:12 PM
KrzyFast's Avatar
Guys, has anyone ever looked in or under the steering column to see if the wiring for the radio controls is there? if so, could you not use a SLK 32AMG steering wheel or at least the radio controls from the wheel to put the SRT6 into dyno mode. it is the same software, basically the same car for that matter. I bet the wiring is there, just need to be able to tap into it and presto! Dyno Mode on a SRT6!
Thoughts?
Cheers,
KrzyFast
Old Oct 26, 2008 | 07:20 PM
apkano's Avatar
Life is random...so am I.
Get your hands on $60,000 worth of Mercedes STAR software and computer and you're good to go.
Old Oct 27, 2008 | 12:37 AM
Guran's Avatar
Is it possible by the Star prog to put the car in Dyno mode ?
/Göran
Old Oct 27, 2008 | 03:03 AM
apkano's Avatar
/Göran
I wouldn't have posted that if I hadn't seen it done.
Old Oct 27, 2008 | 05:37 AM
Guran's Avatar
Ok.
Thanks
Old Oct 27, 2008 | 05:41 AM
Guran's Avatar
AMG answer on my Dyno mode question:
Thanks for the explication.
We regret to inform you that it is not possible to put your SLK32 into the
dyno mode.
Best regards
Mercedes-AMG GmbH
Daimlerstr. 1
71563 Affalterbach
www.mercedes-amg.com"
/Göran
Old Oct 27, 2008 | 08:28 AM
MikeR's Avatar
Guran, go find a 4 wheel dyno and let it rip. I think the highest mine has been is 5850rpm on a Mustang, 2 wheel, dyno. I do have a new LET tune and intake plenums to go test. I have only used that same dyno for all testing so far.
MikeR
Old Oct 27, 2008 | 08:37 AM
MMZ_TimeLord's Avatar
Any competent shop that can tune a Mercedes driveline can put your car into dyno mode through the diagnostic port.
Old Oct 27, 2008 | 03:13 PM
Guran's Avatar
Thanks
I will try that. ( and a short test drive on the road to )
/Göran
Apr 28, 2016 02:04 AM
johnnycross413
Mar 4, 2016 04:49 AM
Sep 28, 2015 07:40 PM
Billy22Bob
Sep 18, 2015 08:57 AM
RacerXofFL
Sep 15, 2015 05:00 PM
