how to install boost gauge in manifold
Old Nov 5, 2008 | 10:49 AM
Default how to install boost gauge in manifold
You need a drill 29/64 or 15/32 ,, a 1/4"-13 NPT tap, this will give you a 1/4 pipe thdin to the manifold .
first i found and marked a spot on the manifold where i wanted the fitting, removed the manifold, drilled tapped washed with hot water and soap. screwed the 1/4 X 1/8 fitting into the mainfold got it snug + 1/2 turn looked inside seen how much was sticking into the manifold,,marked it removed the 1/4 fitting cut off about 4 thds reinstalled and tighten it was just past flush inside the manifold, reinstall the manifold,, connect the 1/8 fitting that came with the gauge and tested it. will put gauge in cabin soon ,, it is very simple to do. ,,
good luck jim
Jonacross
20
Jul 17, 2017 11:19 PM
Dec 2, 2015 12:49 AM
zackman62
Nov 6, 2015 12:37 PM
xfireon20z
Sep 10, 2015 04:27 PM
crmnal
Sep 6, 2015 08:07 AM
