Headlight Help
Old Nov 7, 2008 | 09:15 AM
scott weber's Avatar
Default Headlight Help
I am in need of some assistance. I have a broken retaining clip that holds the high beam bulb in place. Dealer did some research and found I will need to purchase the whole headlight assembly....$534. I was wondering if any member might have an extra assembly that had been damaged and replaced. I checked a couple of bone yards with no luck. Bulb is semi secure for now but don't know how long. THANKS
Old Nov 7, 2008 | 09:36 AM
Default Re: Headlight Help
try Ebay, sometimes some are also available that have been changed out under warrantee. Is yours out of warrantee?
Old Nov 7, 2008 | 09:44 AM
maxcichon's Avatar
Could you make your own?
McMaster Carr.
.015" stainless spring wire.
Part Number: 89045K31 $14.37 Each
Material
Super Corrosion-Resistant Stainless Steel (Type 316)
Finish/Coating
Bright
Shape
Wire
Wire Type
Standard
Wire Diameter
.015"
Wire Diameter Tolerance
±.0004"
Tolerance
Standard
Material Certification
Without Material Certification
Gauge
26 AWG
Wire Form
1/4 lb. Coil
Approximate Feet per Coil
414'
Condition/Temper
Spring Temper
Hardness
Not Rated
Tensile Strength
195,00 to 270,000 psi
Maximum Temperature
570° F
Specifications Met
American Society for Testing and Materials (ASTM)
ASTM Specification
ASTM A313, ASTM A555
Old Nov 7, 2008 | 11:41 AM
Bought used 1 year ago, purchased warrenty does not cover part,will check e-bay and or possible make my own. What a pain in the ***.
smfrycruzr
Jul 17, 2023 05:33 PM
srtmodder
Aug 23, 2017 08:28 PM
Franc Rauscher
May 9, 2016 12:04 PM
gp1200x
Dec 6, 2015 12:59 PM
RacerXofFL
Sep 15, 2015 05:00 PM
