LEDs in side markers... warning light on dash?
Old Nov 20, 2008 | 08:10 AM
Default LEDs in side markers... warning light on dash?
Thanks to Maxcichon for the front silver amber 194s for my clear corner markers. Recently I bought inverted red LEDs for the rear clear markers. They color is a perfect match for the tail lights vs. red 194s.
So now how do I get the dash warning light off? It thinks both rear corner bulbs are out because the LED draw is not enough. Is there something I can do without disturbing the factory harness?
Any help is appreciated. James
Old Nov 20, 2008 | 09:03 AM
maxcichon's Avatar
Exclamation Re: LEDs in side markers... warning light on dash?
Yep, you can buy "Load Resistors" for ~ $15-$25 each. Or make them for ~ $3 each.
Give me a few minutes and I'll make a how-to for the forum?
P.S. You'll need one for each LED.
Old Nov 20, 2008 | 09:25 AM
maxcichon's Avatar
Default Re: LEDs in side markers... warning light on dash?
OK, I found some really well priced bits.:
http://www.superbrightleds.com/cgi-b...gi?product=CAR
You are looking for the 25 watt/25 Ohm sets. (RL-2525 Marker Lamp Load Resistor)
Or do this:
Parts List/Load Resistors
22-18 ScotchLok Power Tap
And make an assembly like this:
Then crimp the ScotchLok connectors in parallel with the LED.
You will need to solder the wires to the resistor taps.
Old Nov 21, 2008 | 05:38 AM
Thanks Max. The cold weather has set in here and my garage has just enough room left to park the Crossfire. So I need to wait for a warm spell to work on it in the driveway. Thanks for the help and I understand what you explained.
Is it possible Radio Shack would have what I needed? I am 2 minutes away from one.
Thanks again, James
Old Nov 21, 2008 | 06:09 AM
maxcichon's Avatar
No, I don't think so. They are special-application resistors.
The link to the pre-made units use the same Dale-Vishay resistors, and sell them for $3.95 each. Plus $5 shipping.
What you're looking for is ~ 3/4 the way down that page.
That, sir is cheap. I would order them there. A lot less hassle!
Let me know?
PNA
Nov 12, 2020 04:44 PM
Kodebuster
Nov 5, 2020 04:06 PM
Adrian_X
Nov 9, 2017 08:49 AM
westonrose
Jul 14, 2015 11:25 PM
Adrian_X
Jul 12, 2015 11:05 PM
