oil filter question
Old Dec 20, 2008 | 09:12 AM
v8valiant's Avatar
Default oil filter question
ok i got my k&n filter and on the instruction note it shows two lines and the filter housing must go past the first line and come close to the second line, i cant seem to find any way to slip it on further the o rings are all lubed up tried twisting and pushing till the filter started to flex, the old filter and the new one are identical! anyone run into this ? any ideas? thanks alot!
Old Dec 20, 2008 | 09:33 AM
MikeR's Avatar
Default Re: oil filter question
Double check your O rings, relube them and try again. That last little bit is a bit of a force fit. It kind of pops in. I dont recall if mine flexed or not when I did the last push on.
MikeR
Old Dec 21, 2008 | 06:32 PM
brianm929's Avatar
I put on the same filter and it was a tough go to get it to go on. You have to twist it on just like the diagram indicates. It does eventually go.
Good Luck,
Brian.
deerhunter
Jan 16, 2021 10:56 AM
PNA
Nov 12, 2020 04:44 PM
xfireohio
Jul 20, 2020 12:03 AM
sittininthesun
Aug 24, 2015 10:47 AM
steps
Jul 27, 2015 03:14 PM
