What is this flashing symbol on my ODOMETER!!!
Old Mar 5, 2009 | 09:29 AM
Chased316's Avatar
Default What is this flashing symbol on my ODOMETER!!!
OK so just to clear the air I did do a search ahead of time and looked in the owners manual and I couldn't find the answer I know this is a very easy question but here goes. when I start my car in the odometer widow a lightning bolt sort of looking thing(maybe it's a quantity indicator?) flashes with the number -100 next to it? Any idea what this is? Thanks for your help in advance!
Old Mar 5, 2009 | 09:45 AM
danimal's Avatar
Default Re: What is this flashing symbol on my ODOMETER!!!
You are 100 miles overdue for service (by the FSS). If you've had the oil changed, the FSS was not reset....or you are in fact due.
Old Mar 5, 2009 | 10:28 AM
Chased316's Avatar
ok...that's what I thought it was but just wanted to make sure. I'll have to reset the FSS thanks!!!
Old Mar 5, 2009 | 11:16 AM
Isn't it supposed to actually warn you before you go overdue?
Old Mar 5, 2009 | 04:07 PM
VQ35DE's Avatar
I guess it could also mean 100 days overdue too.
Old Mar 5, 2009 | 07:33 PM
Chased316's Avatar
it could mean 100 years over due also
Old Mar 11, 2009 | 09:58 PM
Jay-Impala-man's Avatar
It is to let owners know something on our cars could be wrong and to take it in to the dealer. A way to get your money!!! I just need to know how to re-set? I just changed my oil. I am showing to have serviced in 21 days....Help, and Thanks, Yellow rag-top.. Jay-Impala-man kkjc805@netscape.com
Old Mar 11, 2009 | 10:06 PM
Just a way to get your money. I have mime telling me to get car aerviced in so many days. How do I re-set? Help... Jay-Impala-man kkjc805@netscape.com
Old Mar 12, 2009 | 04:54 AM
GDC-SRT's Avatar
FSS Reset
1. turn the key to the on/run position.
2. within 1 second press the **** to the left of the display twice.
3. present status for days remaining or distance traveled is displayed. within 10 seconds turn key to off.
4. press and hold **** on left side of display while turning key to on/run again. present status is displayed once more. continue to hold button. after approx. 10 seconds a tone sounds and the display shows 6,000 miles for approx. 10 seconds.
5. release the ****
You should be able to do this. It takes a few attempts to get it right. One pointer ...the 10 seconds in step 3 refers to 10 seconds after the key is turned to the ON position. You have to turn it off before that expires. Let me know how it turned out.
Old Mar 12, 2009 | 10:38 AM
Jeff Cobb's Avatar
Don't be frustrated if this doesn't work the first try.
It took me three shots to get the timing right.
At least the "-100" isn't a self-destruct countdown.
Old Mar 16, 2009 | 11:37 AM
ayayay's Avatar
That procedure is in the Owners Manual Chapter 4: Understanding Your Instrument Panel on Page 107.
After going in the car to get it when I'm indoors and then vice versa many times, I now keep the hard copy in the glove box and I downloaded the PDF file for in the house, get it here http://www.chrysler.com/en/owners/manuals/index.html Any model or year
Old Mar 16, 2009 | 12:00 PM
rodimus's Avatar
There wrenches by the way.
That's about all the info I'm good for.
Old Mar 23, 2009 | 06:43 AM
caddyman3's Avatar
damn...i thought that meant lightning mode was engaged
Old Mar 23, 2009 | 11:01 AM
danhaman's Avatar
I have -730 showing is that any different? I can understand -100 but -730 doesn't make much sense, so I just want to make sure it's not a code or something like that...like 730=differential fluid or the like.
Dh
Old Jul 18, 2010 | 04:00 AM
Joliet John's Avatar
I'm guessing here, but it resets to 7000 miles. It counts down from there to zero, at which point you're supposed to get the service done. If you don't, it keeps counting down, which puts you into negative numbers. So, in your case, you should have changed your oil 730 miles ago.
Old Jul 18, 2010 | 04:12 AM
I just service mine once a year....lol....then again, they are just for fun, not daily drivers...
northwest_crossfire
May 30, 2016 05:19 PM
steps
Oct 13, 2015 06:18 PM
waldig
Sep 17, 2015 10:35 AM
davidc90
Sep 6, 2015 10:37 PM
MickeyNasty
Sep 6, 2015 08:29 PM
