Keeping it cool! The engine that is.
Old May 18, 2009 | 10:27 AM
nate_man's Avatar
Default Keeping it cool! The engine that is.
I have noticed that my engine gives off a ton of heat when I get out after a good drive. It appears as if this iengine is running and cooling as normal and the temp guage is reading fine so my question is more on the bottom cover that we need to remove when changing the oil.
Has anyone removed this permanently to let the engine breathe cool off a little quicker. The engine bay with the sealed trim around the hood seems to make the engine bay an oven.
This may be because I am in the super oven state of Florida, but there has to be some benefit in letting the bay get a little more air. Agreed we may loose a little smooth air flow uner the car but I wonder if the heat dissipation is worth it.
Thoughts, comments, suggestions?
Old May 18, 2009 | 11:11 AM
maxcichon's Avatar
Default Re: Keeping it cool! The engine that is.
https://www.crossfireforum.org/forum...ld-delete.html
And ppro started one too...
Old May 18, 2009 | 11:22 AM
LantanaTX's Avatar
Took mine off a year ago to take measurements for the V8 and haven't put it back on. Less heat and I don't have to worry about the oil change monkey not getting it back on right.
Old May 19, 2009 | 01:36 PM
TVT_DESIGN
Guest
Posts: n/a
Our car runs with no pan, a modded t-stat, no engine cover, and 60/40 water:antifreeze with water wetter. It also has a 2 QT Oil cooler. After an hour of hard driving the thing is still cooler then usual.
Old May 19, 2009 | 02:33 PM
tighed1's Avatar
Hmmmmmm.
Sounds like a worthy mod.
waldig
Jul 31, 2017 09:46 AM
waldig
Sep 2, 2015 11:02 AM
waldig
Jul 30, 2015 07:39 PM
waldig
Jul 29, 2015 06:54 AM
Bifftws
Racing
Jul 28, 2015 05:31 PM
