troubleshoot stock radio issue
Old Jun 23, 2009 | 01:35 PM
typhoon55's Avatar
Default troubleshoot stock radio issue
After a water leak on passenger side due to clogged cowl vents, the radio is not working...
it powers up and shows radio station / song etc. but only a muffled sound from sub woofer . no sound from speakers. checked fuses #5 & 8 & 23.
Obviously water probably caused it but I am hoping it did not do serious damage.
The power amp is located in passenger footwell so I suspect it was damaged from water
I removed the amplifier and the connectors were water damaged. I noticed 2 leads in particular that had green corrosion with red / yellow stripe that is power to fuse 23 in wiring diagram ?
Old Jun 23, 2009 | 05:26 PM
XFiringInNC's Avatar
Default Re: troubleshoot stock radio issue
I'd suspect that it's toast and replace it.
Old Jun 23, 2009 | 09:51 PM
typhoon55's Avatar
any leads on a used oem power amp or would I be better off going with something else?
Old Jun 24, 2009 | 10:50 AM
SNAKEWOLF's Avatar
LKQ Online
I HAVE GOTTEN PARTS FROM THEM
Old Jun 25, 2009 | 01:34 PM
typhoon55's Avatar
I found a used factory amp to replace the fried one.
How can I reattach the wire - red/yellow that goes in the back of the 12 pin amp connector ? The wire was corroded and was loose - Is it simply just pushing a newly stripped end into pin hole? What holds the wire into the pin hole on back of connector? It seems maybe there was a metal type pin that gets attached to wire then pushed into plastic connector.
PNA
Nov 12, 2020 04:44 PM
MAXIMUM
Aug 4, 2015 11:04 PM
pioneer4x4
Jul 27, 2015 02:04 PM
gtjl
17
Jul 22, 2015 06:28 PM
xzmilan
Jul 22, 2015 10:40 AM
