Service reset
Old Jul 4, 2009 | 11:59 PM
Charles Moore's Avatar
Unhappy Service reset
I changed the oil and filter in my 2005 SRT, and now cannot get the FSS to reset to 7000miles. I have done the procedure as outlined in the owners manual multiple times, but the FSS still shows a minus mileage figure, that becomes a larger minus number as the car is driven. Could using a different viscosity of oil( I used 5W30 Castrol Syntec) cause the FSS not to reset? Suggestions??
Charlie Moore
Old Jul 5, 2009 | 01:06 AM
GDC-SRT's Avatar
Default Re: Service reset
Review the procedure, and try again it can be finicky.
Oil viscosity has nothing to do with it.
Good luck.
Old Jul 5, 2009 | 01:08 AM
It seems to take several attempts to get these things reset but keep trying and I'm sure you will get it reset.
Old Jul 5, 2009 | 01:17 AM
apkano's Avatar
Life is random...so am I.
+1 on what GDC and Valk said....... sometimes it just takes the "knack" of getting the timing right on the reset procedure.
I 100% guarantee that the change in viscosity has nothing to do with it.
If you don't believe me.......I'll come over and drain all the oil and replace it with sand, then reset the FSS.
Old Jul 5, 2009 | 12:41 PM
Iamfink2's Avatar
I reset mine by doing a couple dry runs without pushing any buttons then when I actually reset mine I usually get it on the first try.
Old Jul 5, 2009 | 11:59 PM
magneticred's Avatar
1. Turn key to the ON/RUN position.
2. Within one second press the ****/button twice.
3. The present status for days or distance is displayed.
Within 10 seconds turn the key to OFF/
LOCK.
4. Press and hold the ****/button, while turning
the key to ON/RUN again. The present status for
days or distance is displayed once more. Continue
to hold the ****/button.
After approximately 10 seconds, a signal sounds and
the display shows 7,000 miles (Canada: 11,000 km) for
approximately 10 seconds.
5. Release the ****/button.
When you do the above make sure that you turn past the accessory position to the on position (but not all the way to start). In the accessory position you will see the display and this may make you think that you turned the key far enough - the "dummy" lights need to come on to be in the on positon. Also the above is very sensitive to following the time limits.
Old Jul 6, 2009 | 08:05 AM
theglot's Avatar
My big question is about item #2. Does this mean that you have to press the **** twice within one second of turning the key to ON or does it mean you have to press the **** twice within 1 second?
It took me 4 tries to get mine reset.
LOCK.
Old Jul 8, 2009 | 11:48 PM
ivo 1's Avatar
it worked!!!! it really really worked!! now all i have to do is change the oil., lol
Old Jul 9, 2009 | 10:18 PM
CALL911's Avatar
It ALWAYS takes three or four times for mine to reset. I think I can change the oil faster than I can reset the FSS
Old Jul 9, 2009 | 10:28 PM
tighed1's Avatar
Woo-hoo!
Worked first time! (on the roadster)
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Abaton6
Sep 24, 2015 10:14 PM
stelrz1
Sep 21, 2015 11:18 AM
tritongreen
Sep 18, 2015 07:32 AM
