Hissing sound coming from engine bay
Old Oct 26, 2009 | 07:07 PM
samo59's Avatar
Default Hissing sound coming from engine bay
So that is what I have folks. I got a faint hissing sound coming from my eninge bay, not loud. Car drives perfectly fine, no codes other than the Secondary Injectin System. I checked for any loose or broken vacuum tubes but could not find anything. And wouldn't a broken vacuum tube trigger a check engine light? Anyone have this same noise?
-Sam
Old Oct 26, 2009 | 07:26 PM
LantanaTX's Avatar
Default Re: Hissing sound coming from engine bay
This may be your idler pulley. you can confirm this by taking a very large screw driver and hold the blade end against the center that is not turning and hold your ear to the handle of the screw driver while the engine is idling. Be very careful! This is an old school method that mechanics have used for years. My grandfather taught me this about 35 years ago. Or if you are a doctor you can use your stethoscope.
Old Oct 26, 2009 | 08:00 PM
Do you have an oil catch can?
Old Oct 26, 2009 | 11:50 PM
ZAHANMA's Avatar
Is the hiss only under partial load?
Old Oct 27, 2009 | 07:51 AM
spensley's Avatar
What area of the engine is the hissing coming from?
Old Oct 27, 2009 | 05:27 PM
samo59's Avatar
Haha lantana I know that old trick haha, havent done it though. The hissing is only at idle and it sounds like it's coming from the right side, if you were standing in front of the car. FP, I do not have a catch can.
-Sam
Old Oct 27, 2009 | 05:36 PM
check all the hoses, right side the engine as well as behind and under the throttle body...now if it were my car....it would be the sucking sound of the needswing duel cai....lol
Old Oct 27, 2009 | 07:12 PM
waldig's Avatar
Talking Re: Hissing sound coming from engine bay
allow me to repeat this trick.
Get a hose 3-5 feet long and stick one end in your ear and probe with the other end STAYING away from moving belts and fans thinggies. Woody
This should be a sticky for finding noises, locations. Woody
Old Oct 27, 2009 | 07:27 PM
32krazy!'s Avatar
folks please go to harbor freight and spend 2.99$ for a mechanics stethoscope! its cheap and safer than a hose or screwdriver
Old Oct 28, 2009 | 09:29 PM
samo59's Avatar
Haha i've also heard with a piece of wood but that is useful for mechanical/metal noises like engine knock or scraping. I'll check to see if any hoses are disconnected or if the belt is scraping on something. Thanks for the help guys!
-Sam
Old Oct 28, 2009 | 11:42 PM
Is your cat missing?
Old Oct 29, 2009 | 03:24 PM
samo59's Avatar
Hahaha naw I dont have a cat haha.
-Sam
IGot2P
Jul 26, 2025 12:40 PM
wruss
Feb 8, 2017 01:05 PM
northwest_crossfire
May 30, 2016 05:19 PM
BrenLW
Aug 5, 2015 04:53 AM
axnguyen
Jul 21, 2015 11:41 AM
