Kleemann supercharger
Old Jan 18, 2010 | 12:01 PM
cassidyrj1's Avatar
Default Kleemann supercharger
Kleemann M112 SuperCharger System Mercedes SLK320 V6 R170 96-04 I wonder if that would be a improvement over the srt supercharger.
Old Jan 18, 2010 | 12:37 PM
bmorgan's Avatar
Default Re: Kleemann superharger
Wow.... A low boost SC that can be used safely of the NA engines that shows gains of 113 HP and 97 lbs/ft Torque. Pretty impressive.
If I am reading correctly, it would not be an improvement over the SRT SC, but would be a helluva add-on to the NA if you could afford it. For $7,500.00 I think I would just get the SRT, but if you could find one of these babies used.....
Old Jan 18, 2010 | 12:50 PM
JHM2K's Avatar
Or if you reeeeeeeeeeeeeeallllly liked your Alabaster...
Old Jan 18, 2010 | 12:53 PM
bmorgan's Avatar
Very true, and with those gains, it basically gives you stock SRT numbers. Makes you think!!! So, who is going to be first to supercharge their NA?
Old Feb 10, 2010 | 10:07 AM
brian_omeara07's Avatar
Chuck Norris?
Old Feb 12, 2010 | 11:35 AM
///SilverSaphRT6's Avatar
Originally Posted by brian_omeara07
Chuck Norris?
aaaaaaaaaaaaaaaaaahahahha LMFAO.....priceless!!
Old Feb 12, 2010 | 12:10 PM
TVT_DESIGN
Guest
Posts: n/a
We have a customer that did this to his v8 and the intercooler and SC is far superior to the OEM MB set up. He built his engine to hadle some decent boost and puts down 460-480 RWHP on pump gas, stock internals.
Old Feb 12, 2010 | 04:11 PM
SRT6_Roadster's Avatar
Be careful with this kit. I have a friend who installed this kit and at least on the older ones there was no safety for when the IC pump went. He found out the hard way that his pump died - a hole in the engine. At least on the older kits the crappy bosch pump was used. When the car was running right it was a strong car.
Old Feb 12, 2010 | 07:11 PM
TVT_DESIGN
Guest
Posts: n/a
This kits are true bolt on, but we would never recommend that. There are a large number of things that need to be improved for reliability and efficeincy. The pump being one of them. Also the Intercooler can be reworked, the intake system, fuel system, TB, MAF sensor, and a few more odds and ends. All of these things make a ton of difference. Then you can start playing with the fun pulleys!
Old Feb 13, 2010 | 12:01 AM
ProjectMayhem's Avatar
If i had the cash i would love to try and 1040ax 2.3L whipple! at about 27psi =)
Old Feb 14, 2010 | 06:10 PM
KrzyFast's Avatar
Default Re: Kleemann supercharger
Am I looking at the pic right, meaning the SC is on the bottom and the intercooler is on top, just like the Cadilliac STS V? If so, then that is a whole lot better getting the IC out of the "V" of the motor where it can be cooler!
Cheers,
KrzyFast
Old Feb 14, 2010 | 10:18 PM
TVT_DESIGN
Guest
Posts: n/a
Cheers,
KrzyFast
Yup, much better set up.
Old Feb 14, 2010 | 11:25 PM
kenyonmjr6's Avatar
I wonder what those numbers would be if you have a TVT300 upgrade done along with the Kleeman system.
Old Feb 15, 2010 | 12:41 AM
billvp's Avatar
I haven't looked into this much at all, but am curious why it would not seem to be considered an upgrade/improvement for SRT6 owners.
Old Feb 15, 2010 | 03:47 PM
KrzyFast's Avatar
Bill, depends on the size of the SC I would say. If they are the same size, that is a whole lot of $$$$ to cool the intake charge, by how much???
Cheers,
KrzyFast
Old Apr 30, 2010 | 09:13 AM
ZAHANMA's Avatar
For 9,000.... I could get an amazing paint job, and paint my SRT-6 Alabaster.
Old Apr 30, 2010 | 07:43 PM
kurtisberry's Avatar
Good thinking ZAHANMA. Alabaster rules.
gblack32
Sep 7, 2016 08:27 PM
zackman62
Nov 6, 2015 12:37 PM
UNDER PSI
Nov 1, 2015 09:39 PM
tom2112
Oct 26, 2015 08:18 PM
FiftyThree033
Jul 26, 2015 09:24 PM
