central locking pump /security pump module
Old Feb 5, 2010 | 06:03 PM
bibbs's Avatar
Question central locking pump /security pump module
Looking for where the pump is in a 2004 coupe. The 2004 manual says its in the luggage compartment under the rug next to the jacking system. Its not there and it it not shown in the 2006 parts manual. In all the technical data it is shown as part of the security system.
Old Feb 5, 2010 | 07:31 PM
Toolman's Avatar
Default Re: central locking pump /security pump module
The Electronic Control Module section of the service manual provides this information:
1. Disconnect the negative battery cable.
2. Remove the trunk floor covering.
3. Remove the vehicle jacking assembly.
4. Remove the sound deadening foam material from the central locking pump/security system module.
5. Disconnect the air lines (1) and the electrical connectors (2) from the central locking pump/security system module
(3) and remove the module.
Good luck.
Old Feb 5, 2010 | 07:46 PM
It's on the right hand side in the top right hand corner, To get at it remove the mat and the trim that is on the side of the car which hides the wheel well and gas fill pipe from the gas cap.
For your interest I copied the following which explains how the system works.
I am looking for a photo on the site and it shows the pump. No luck so far though.
VEHICLE LOCKING/UNLOCKING
To unlock, the Body Control Module is actuated by the SKREEM. The Body Control Module then sends the signal
to the Central Locking Pump/Security System Module (CLP/SSM) via the Controller Area Network (CAN) Bus. The
CLP/SSM pump motor starts running and supplies air pressure. The door lock actuators are pressurized. When a
pressure threshold is reached in the system, the pump is switched off by an internal pressure switch. The pressure
in the system is then released by the CLP/SSM and the unlocking operation is completed. The locking procedure is
accomplished in a fashion opposite to the unlocking operation. However, the next time the remote control button is
pressed, the CLP/SSM is also actuated by connecting it to ground by the second control lead on the SKREEM. The
direction of rotation for the CLP/SSM pump motor is reversed, thereby providing the vacuum required to lock. In
order to avoid unlocking the vehicle unintentionally, the vehicle is relocked by the CLP/SSM via the SKREEM.
Relocking is accomplished after unlocking with the remote control when: a door is not opened within 40 seconds,
the key is not inserted into the ignition lock, the interior power door lock switch is not actuated, only the liftgate is
opened after unlocking. The CLP/SSM reads the signals (door contacts, trunk lid, interior power door lock switch)
and actuates the power door lock actuators. The vehicle security alarm is also activated by the relocking function.
Old Aug 3, 2023 | 03:49 PM
Silviocrow's Avatar
[QUOTE=bibbs;460181]Cerco dov'è la pompa in una coupé del 2004. Il manuale del 2004 dice che è nel bagagliaio sotto il tappeto accanto al sistema di sollevamento. Non c'è e non è mostrato nel manuale delle parti del 2006. In tutti i dati tecnici è indicato come parte del sistema di sicurezza.[/QUOTE
Buongiorno ho una Roadster del 2004 avrei bisogno di una pompa per la chiusura centralizzata, potete aiutarmi..?
Old Aug 4, 2023 | 06:48 PM
zip439's Avatar
[QUOTE=Silviocrow;981527]
ebay UK: pump
Old Mar 23, 2026 | 07:37 PM
Attila's Avatar
Hello, my 2005 crossfire all of a sudden wont stay running. 3 times it turnsover and dies, the 4th time it doesn't turnover any more. Ive tried all the different sequencies with the key fob but nothing. The previous owner even sent in the SKREEM module to make it so this wouldn't happen again. What am I missing?
Old Mar 23, 2026 | 09:24 PM
First things to check:
Battery: are the cables tight on the terminals? How old is the battery? If the car isn't getting enough voltage, it won't start.
Relay Control Module: One of the relays could be bad and causing it not to start.
Scan for Codes: Are you getting any codes? You might have to scan it as a 2003 Mercedes-Benz SLK 320.
Swimdad
May 16, 2024 12:44 AM
Sixkay
Sep 20, 2021 11:18 AM
foxxfire7
Jan 3, 2016 09:09 PM
InfernoRedXfire
Crossfire Events and Meets
378
Sep 16, 2013 08:40 AM
purdy2005crossfire
May 16, 2011 10:18 PM
