Installing Needswings CAI
Old Feb 6, 2010 | 04:48 PM
crookedview's Avatar
Default Installing Needswings CAI
I acquired a Needswings intake from another person, so I do not have the instructions (unless someone wanted to send me the PDF ), and I'm wondering how the MAF sensor wiring is dealt with. My first guess is that I just need to take off the wire covering and extend each of the wires, is that correct?
Thanks for any help..
Old Feb 6, 2010 | 04:57 PM
bmorgan's Avatar
Default Re: Installing Needswings CAI
Here you go.
File Type: pdf
Old Feb 6, 2010 | 05:06 PM
bmorgan,
Thanks, but I guess I should've specified that I have the NA Crossfire - I don't see any MAF sensor-specific instructions in that document.
Appreciate the quick response, though
Old Feb 6, 2010 | 05:26 PM
bmorgan's Avatar
Oops.... sorry. Hopefully someone else will help you out shortly. Good luck with it.
Old Feb 6, 2010 | 05:29 PM
32krazy!'s Avatar
email rob @ needswings. he would be able to email the directions .
Old Feb 6, 2010 | 06:17 PM
bluecoupe's Avatar
Sorry it took me so long to respond......I'm still on dial-up!
File Type: pdf
Old Feb 6, 2010 | 06:55 PM
Awesome, thanks guys. You're a huge help!
Old Feb 7, 2010 | 12:54 AM
Okay, so that didn't go so well..
Installed a 74mm throttle body at the same time as the intake (acquired TB from same party as intake) and I'm guessing it was bad. Had the TB and CAI installed and when I started the car it would sputter, revs would jump around and eventually shut off.
At first I thought it was the breather hose, since there was a bit of a kink in it, but straightening that out didn't seem to resolve the issue. Then, I thought it might be the MAF sensor, but unplugging that basically shut the engine off right away.
Left the battery unplugged for about 10-15 minutes and the same thing happened. Revved a bit, sputtered, and eventually shut off.
Put the old TB back on and the stock TB 'elbow' assembly and everything seems to be fine. Scared me that I messed my car up :\. Can't test-drive it with all this frickin' snow!
Any ideas on what was going on, other than maybe a bunk TB?
Old Feb 7, 2010 | 01:25 AM
Infinite's Avatar
did you swap boards in the throttle body? if it still has the board from the supercharged motor, it work.
Old Feb 7, 2010 | 01:40 AM
Infinite,
I did not - The part number of the new TB is the same as my stock one, however, the 74mm one has been bored and a new butterfly valve installed.
Good idea, though. I will try that eventually (afraid to touch my car now).
55chevy
Jul 22, 2024 02:31 PM
Jonacross
20
Jul 17, 2017 11:19 PM
zackman62
Nov 6, 2015 12:37 PM
Ralph289
Sep 21, 2015 09:34 PM
crmnal
Sep 6, 2015 08:07 AM
