What Type Battery do we Have?
Old Apr 3, 2010 | 09:22 PM
Default What Type Battery do we Have?
Can anyone tell me what battery type do our cars come with?
12V Standard
12V AGM
12V Gel Cell
Old Apr 3, 2010 | 09:24 PM
Default Re: What Type Battery do we Have?
Why, did someone come out with a chrome one?
Old Apr 3, 2010 | 09:29 PM
Old Apr 3, 2010 | 09:30 PM
LOL, I wish.
I bought a charger for my battery. I didn't start the car more the once this winter, so it was dead. I don't know much about batteries. The charger has these three settings. I assume it's the "standard" battery, but I thought I would ask.
Old Apr 3, 2010 | 09:33 PM
Originally Posted by FP
LOL, I wish.
that will work, usually asks if it is maintenance free or not....if it is the original, you need to replace it....I am replacing mine as soon as Rob gets more of the light weight ones in he is selling...do you have a "chrome" battery charger by chance?
Old Apr 3, 2010 | 09:36 PM
Tell me more about these light weight batteries...
Old Apr 3, 2010 | 09:45 PM
shuriken 14lbs......same cranking power as the stock battery...90 bucks less our discount....
Old Apr 3, 2010 | 09:55 PM
How heavy are the OEMs?
Old Apr 3, 2010 | 10:07 PM
at least twice that....
he has them listed on his site....under ignition, I believe...
Old Apr 3, 2010 | 10:22 PM
velociabstract's Avatar
I think the stock batteries are around 40 lbs. I have one of the shuriken 14 pounders on the way too. My battery charger is so old that it only has 2 choices, 6 volt and 12 volt. (vintage 70's craftsman) Yours is not a gel cell. Standard would be my guess.
Les
Old Apr 3, 2010 | 10:43 PM
"Standard" is what I guessed. I have it charging now. Lets hope it takes and holds until I get the new one from Rob.
Old Apr 4, 2010 | 12:20 AM
IBLUBYU's Avatar
FP ....you absolutely have a "standard" battery. That is, if it is the original battery, and not one that was added by a previous owner
The 12V AGM is a specialized "absorbed glass mat" unit with calcium lead plates that allows for long term discharge draws in the case of trolling motors, winches,etc. and are extremely $$$$$.
12V gel cell, are like the Optima batteries which actually could be installed upside down and still work great. Very often used in "marine type' applications.
Hope this helps........
Old Apr 4, 2010 | 08:21 AM
Well the charges is showing 100% charged this morning. Let's hope it holds. It is a Mopar battery that was put on by the dealer when I bought the car with 3K miles on it in 2006.
Thanks for the battery info IBLUBYU.
Old Apr 4, 2010 | 12:55 PM
IBLUBYU's Avatar
Your Very Welcome Sending you a PM....
Old Apr 4, 2010 | 02:45 PM
Got it. Hope to see you in a couple of weeks.
Old Apr 15, 2010 | 02:10 PM
kenyonmjr6's Avatar
FP you should have just bought a redtop Optima. They last FOREVER.
Old Apr 15, 2010 | 04:12 PM
beasticles's Avatar
Just installed my interstate HTP-91 "Megatron Plus" last night. $136 at the local auto parts shop. Thing weighs in at 37lbs. I think the VARTA brand battery that came standard with our cars that I removed last night weighs in at about 55 or 65lbs.
Old Apr 20, 2010 | 09:43 PM
I want to replace mine with the same type and style as the original. It just goes well with the entire under hood experience! Interesting note about the OEM weight, as nimble as these cars are, maybe its neccessary to keep all 4 wheels on the ground? (LMAO)
EDIT: Automotive / Truck Batteries - Mega-Tron Plus - 85 Months - 640 CCA
This is the interstate battery (MTP-H6) they reccommend for the XF on their website. Its also the same one for the MB SLK320. Looks exactly like the one in my car now.
Old Apr 20, 2010 | 10:08 PM
mrobinso, did you have a problem with the length of the battery you put in? Although its longer (by almost 1/2 an inch) then the one recommended, its height is shorter than the one they call for. It also weighs less too! I also notice its more powerful, and less expensive (crazy, that is). Are you sure your part number isn't MTP-91? I could not find part number you indicated anywhere.
Old Apr 20, 2010 | 11:09 PM
MikeR's Avatar
I have the MTP-91 in the Aero and it fits fine.... with a rubber spacer under the clamp of course... it is a little shorter.....
