Water Pump Gone Bad
Old Apr 4, 2010 | 09:44 PM
HowardJ's Avatar
Default Water Pump Gone Bad
It doesn't look pretty, nor sound pretty.
Has anyone replaced theirs? looking for cost and actual parts. I am afraid to drive it to get it fixed, and want to fix it with some help from a friend here.
Dang car is getting expensive.
Need new tires, oil change, tranny fluid change, and now this. awesome.
Old Apr 4, 2010 | 09:50 PM
ChuckNorris's Avatar
Default Re: Water Pump Gone Bad
I just listed the water pump off my car on ebay. Pretty easy to replace.
Chrysler Crossfire Mercedes M112 V6 water pump used : eBay Motors (item 300414463205 end time Apr-11-10 18:34:53 PDT)
Old Apr 4, 2010 | 10:14 PM
HowardJ's Avatar
is there an exact part number for it?
Old Apr 4, 2010 | 11:58 PM
70GT6's Avatar
05097159AC
(non-srt)
Old Apr 5, 2010 | 06:27 AM
waldig's Avatar
Talking Re: Water Pump Gone Bad
Mine got killed when I threw a pulley and smashed the case.
NA and SRT ARE NOT THE SAME............
There are about 14 bolts to do and you need to pull the fan
1. Pull fan
2.Add sheet of cardboard to radiator for protection or hide the results later - your choice.
3. Photo the water pump and make a cardboard template using the new pump. Mark the outline and the holes.
4. Pull off the bolts and inset them in the cardboard template so that they are stored in ORDER.
5.Remove - clean - reinstall water pump.
6. Replace the bolts in their original position, there are different lengths and several hidden in the lower area.
Finish the install and thank me for the template idea at Carlisle.
Assumptions: You have done water pumps before, you have torx socket set, your patient.
Install all bolts b4 you tighten any and use torque wrench ( inch ounce style) to tighten them into the ALUMINUM block.
BLEED the air out twice times when your running. Did I remember to say get a photo of the layout, several??
Enjoy Woody
My time less than 2 hours with a stocked garage and xm radio for stress reduction. OH yeah reinstall and PLUG in the fan....
Old Apr 6, 2010 | 08:55 AM
smpshady's Avatar
how many miles do you have on the XF when it went?
-Steve
Old Apr 6, 2010 | 10:00 AM
HowardJ's Avatar
85.7k
10 characters...
steps
Oct 13, 2015 06:18 PM
o55ie18
Oct 5, 2015 05:50 PM
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
