HELP!!! Mystery no start with a twist
Old May 14, 2010 | 10:36 AM
speeddiva989's Avatar
Unhappy HELP!!! Mystery no start with a twist
2004 Chrysler Crossfire died Tuesday while on the highway. Could not get car started and had it towed back home. I was nervous until I went on the forum and saw that this is a common problem for these car, there are some great posts here.
So I followed the all the threads and figured out it was the RCM, so I got my solder iron out and got to work and heated up the connections with solder (great post from DJ (tighet1) with pics thank you).
Plugged the unit back in and nothing, now I was stuck so after talking to DJ I took the unit back out and soldered the connections. Again car wouldn't start everything as usual came on (fan, radio, windows, etc).
After hours of sitting around I decided like an idiot to check the fuses on the RCM unit and there it was fuse #3 yellow 20 was no good. So I replaced the fuse and car started for about a minute and died again.
I am trying to figure out why fuse #3 yellow 20 keeps breaking.
Any help would be much appreciated.
(one last thing I like to point out I did now of the above LOL all my fathers handy work)
Old May 14, 2010 | 01:50 PM
Default Re: HELP!!! Mystery no start with a twist
The Relay Control Module is a solid state device containing the following internal relays.
These are the relays and there uses.
²
Air Pump Relay
²
Engine Control Relay
²
Traction System Relay
²
Horn Relay
² Fuel Pump Relay
The book says 15 amp for the # 3 fuse.
Could it be the fuel pump that keeps blowing the fuse.
I cannot see what the # 3 fuse actually controls, they label # 1 and # 2 but not # 3.
Old May 14, 2010 | 02:35 PM
²
Air Pump Relay
²
²
²
Horn Relay
² Fuel Pump Relay
Thanks for responding I just checked the manual and this fuse is for the Engine Control Relay, I may of made a mistake on it being #3
Old Jul 23, 2019 | 05:56 PM
grossmj's Avatar
Did you ever find out what was blowing the fuse? Was the entire ECM bad or were you able to determine if it was a specific wire grounding somewhere? This exact problem is happening to my red crossfire as well. Much help needed, I've been battling this problem for the last 4 months.
Old Jul 24, 2019 | 01:15 AM
JSK's Avatar
JSK
This thread is over nine years old.
Old Jul 24, 2019 | 12:22 PM
grossmj's Avatar
I know it is, I was hoping someone who has had this problem would see it and tell me what the exact problem they had was. The service manual doesn't show a 20 amp fuse for the RCM and that's the fuse that keeps blowing every time I try to start my car. Mechanically, I can do almost anything on the crossfire. Electronically, it's another language to me.
minimayhem
16
Aug 23, 2016 07:47 AM
user 8202
Canada
29
Nov 11, 2015 05:27 PM
BEATv1
Sep 10, 2015 12:58 PM
aerobluehal1
Canada
Sep 3, 2015 10:15 AM
Steven 4190
Aug 15, 2015 10:35 PM
