replacement cat for stock exhaust
Old Jul 2, 2010 | 03:25 PM
sr71pyro's Avatar
Default replacement cat for stock exhaust
My girlfriends 04 v6 crossfire's cats are cracking. She needs them replaced ( or potentially not) depending on noise variation. Her exhaust is stock but I'm looking for a replacement cat, hi flow, or regular that will fit on the stock pipe size and I havent been able to find any nor do I know the exact pipe diameter of the stock exhaust. The dealership cost is ridiculous so anything other is suitable. Any suggestions or ideas? Also any sound clips of no rear clips would be awesome. Thanks for the help!!
Old Jul 2, 2010 | 04:10 PM
BrianBrave's Avatar
<--- Huge Horsepower
Default Re: replacement cat for stock exhaust
If there just cracking on the outside and still work - have a muffler shop that can weld stainless steel - grind and spot weld the cracks...
Old Jul 2, 2010 | 04:14 PM
sr71pyro's Avatar
Sorry should have mentioned in first post, but a shop already tried to weld it and then it cracked on the other side. I'm guessing the thing is just old and brittle and the heat is causing it to crack.
Old Jul 2, 2010 | 04:20 PM
Beaner's Avatar
most aftermarket cats will fit in the stock locations if you wanted to go that route. You can also buy the complete peice of pipe with the cat and all the proper bends to just bolt on. your choice
Old Jul 2, 2010 | 04:33 PM
sr71pyro's Avatar
do you think you could provide me with some insight on where to look for these bolt ons or any experience in which cats work. Ebay usually sucks but they sell a "catco" version cat for the left and right sides. thanks
Old Jul 2, 2010 | 04:42 PM
kingkub57's Avatar
Are not the emissions coverage cover the cat converter? which under emission warranty is 8/80 this should cover the cats not unless your out of milage? Just a thought.
Old Jul 2, 2010 | 04:44 PM
sr71pyro's Avatar
at about 130k mileage now so warranty is no good but thanks for the idea
Old Jul 2, 2010 | 05:08 PM
BrianBrave's Avatar
Does your state require emission testing?
Old Jul 2, 2010 | 05:24 PM
sr71pyro's Avatar
im in texas...they might but everytime ive gone to get an inspection...they havent done a sniff test or anything so either they dont care, or I always pick the "best" inspection stations
Old Jul 23, 2010 | 03:37 PM
TomStratRT's Avatar
Is it true that the secondary cats are unmonitored (no O2 sensors)? If so, what happens (or what's the harm) if you remove them? Aside from slightly higher emissions.
Old Jul 23, 2010 | 06:00 PM
mrphotoman's Avatar
you can get new cats on ebay for $30 or so each if you spend a few minutes looking for them.
you may be able to find a few used ones on here for little to nothing.
Old Aug 21, 2010 | 07:28 AM
04 sapphire's Avatar
Hi if u looking for the original one discount catalytic converters.com has the best price
good luck
Old Aug 21, 2010 | 09:03 AM
needswings.com has a cat delete set up that still used the rest of the stock exhaust.
jim
Jul 29, 2015 06:13 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
xzmilan
Jul 22, 2015 10:40 AM
rmcdaniel12
Jul 21, 2015 11:35 PM
