Power your car when its off?
Old Jul 30, 2010 | 07:40 PM
cassidyrj1's Avatar
Default Power your car when its off?
Is there anyway to power your car so it wont die if you wanted to listen to music for a long time? I want to use my car as the sound system for a party but dont want it to die. I also dont want to leave it running the entire time.
Old Jul 30, 2010 | 07:55 PM
BrianBrave's Avatar
<--- Huge Horsepower
Default Re: Power your car when its off?
perhaps trickle charger if you have 110V outlet close by?..
Old Jul 30, 2010 | 08:18 PM
psuperti's Avatar
Yeah, I do that sometimes. I bought a battery charger/maintaner at walmart and plug it to the wall outlet and the car battery. I also have a 1 fared capacitor so it all works well for 3 hours.
Old Jul 30, 2010 | 08:59 PM
Without the ignition switch on the radio will turn off in one hour. I guess you knew that but I thought I would mention it just in case.
A charger would do the trick on a low setting. One of those battery tenders might be just perfect.
Old Aug 3, 2010 | 02:54 AM
aazn's Avatar
id be getting a bigger charger unit..
the aim is to not let the battery drop below 40% i think it was.. because you can permanently damage the battery.
get a bigger charger unit (dont use trickle charge)
get something around the 10AMP-20AMP range..
dont let the battery go flat.
mhajek18
Dec 30, 2015 03:40 PM
Pacemaker
Jun 18, 2015 10:08 PM
WindRestrictor
Jun 16, 2015 12:18 PM
GraphiteGhost
Jun 12, 2015 12:04 PM
WindRestrictor
Jun 1, 2015 02:31 PM
