supercharger cuts out
Old Aug 3, 2010 | 10:45 PM
bucksarrow's Avatar
Default supercharger cuts out
Tonite I had my srt6 out for a drive and made sure it was in summer mode. In drive I could stand on it and it responded very nice. After about 15 miles I tried taking off again and it ran fine until about 60 mph and then it went flat.felt like the supercharger shut off . Any suggestions? Also would like to know how to hook up test light on supercharger so I could see if it is actualy cutting out when this happens.
Old Aug 3, 2010 | 10:57 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: supercharger cuts out
Sounds like Intercooler pump. Do a search.
Old Aug 3, 2010 | 10:58 PM
NeedsWings's Avatar
its probably an intercooler pump failure, they are pretty common. the IC pump quits pumping, the IAT's skyrocket and the pcm see's this, it then turns off the elgagement of the s/c clutch = no boost for you until the IAT's come down.
we have replacement pumps for ~130
Old Aug 4, 2010 | 01:46 PM
Kurts's Avatar
+3!
I'm willing to bet dollars to donuts it's the IC pump.
Feels like it's surging, correct?
You can either stick with the OEM Bosch pump (& I carry a spare thanks to Needswings above) or go after-market & install a Johnson pump in there. Either way, try this first & let us know if this doesn't solve the issue.
Old Aug 4, 2010 | 02:31 PM
bucksarrow's Avatar
thanks for the info I think it is the IC pump also. I have only owned this car since the end of JUNE, 2 of these wks it was in body shop getting front end painted(stone chips) also new windshield.
55chevy
Jul 22, 2024 02:31 PM
zackman62
Nov 6, 2015 12:37 PM
UNDER PSI
Nov 1, 2015 09:39 PM
jaesa
Sep 7, 2015 01:50 PM
FiftyThree033
Jul 26, 2015 09:24 PM
