Will this type air box fit?
Old Aug 19, 2010 | 05:36 PM
Pacemaker's Avatar
Default Will this type air box fit?
I am looking for a MB air box, and have the opp. to get one that fits either a CL 500, or an S 500. Does this type fit our XFs?
Old Aug 19, 2010 | 05:46 PM
Default Re: Will this type air box fit?
If it's a V-8 then I would say no.
If it's the V-6 I would guess not.
Old Aug 19, 2010 | 06:23 PM
Pacemaker's Avatar
"I'll take that as a NO and keep looking. Thanks for your lilting reply. and Thanks JHM2K as well. We may now close this thread.
Old Aug 19, 2010 | 06:48 PM
Infinite's Avatar
If I recall correctly, the airbox portions are the same size in dimension, its only the front piece that is slightly longer.... but the physical airbox is the same, just larger filters.
Old Aug 19, 2010 | 07:24 PM
The 500 is a V8. But if it uses the two piece set-up, the rear airbox will fit. Then all you have to find is a V6 front section, or called the actual engine cover. If you can get a good deal on it, go for it. The front v6 covers come up on ebay quite often.
James
Old Aug 19, 2010 | 07:34 PM
If ithis is the one you want, the rear section will fit. The front is for a V8, not sure how it would look or fit on an Crossfire.
Mercedes CL500 S500 complete engine cover and intake : eBay Motors (item 260651272320 end time Aug-22-10 13:05:17 PDT)
James
Old Aug 19, 2010 | 09:24 PM
Pacemaker's Avatar
Thanx for your gracious and illustrated replies INFINITE and TWO C TER. Much appreciated. May get the one on the link you provided and look for the 6 cyl. front later..
Thanx again guys.
Old Aug 30, 2010 | 04:40 PM
Pacemaker's Avatar
James
Sadly, the back did NOT fit... The clips were not in the right place, too far forward and outboard of the XF rubber mounts. (neither did the front ). I'll keep looking.
Thanks again for your help
PACEMAKER
Old Aug 31, 2010 | 01:05 AM
BrianBrave's Avatar
<--- Huge Horsepower
PACEMAKER
Re-locate the clips....
Old Aug 31, 2010 | 02:16 AM
Infinite's Avatar
gee... I told you so
Old Aug 31, 2010 | 08:49 AM
Pacemaker's Avatar
Sorry, somehow I did not interpret your response as a "NO". Communication is such a challenge..Thanks again for your help.
waldig
Aug 5, 2015 02:29 PM
waldig
Jul 29, 2015 06:54 AM
Romio
Jul 24, 2015 07:04 AM
tom2112
Jul 12, 2015 04:41 PM
cx24724
Jul 12, 2015 11:57 AM
