Dash light says one is out, but cannot find it.
Old Oct 22, 2010 | 05:07 PM
Pacemaker's Avatar
Default Dash light says one is out, but cannot find it.
OK, the Owner's Manual says that certain light bulbs should be checked when the "check light bulb" light comes on on the instrument cluster. Checked them and found them all bright and shiny.
I am still using the orig. battery (made in Spain! )without any problems. Could the battery really be the culprit behind the ghost light in the instrument cluster? Or ??
Old Oct 22, 2010 | 05:28 PM
bluecoupe's Avatar
Default Re: Dash light says one is out, but cannot find it.
Insure both license plate lights are working..............that seems to be the culprit that is missed often.
Old Oct 22, 2010 | 05:32 PM
Pacemaker's Avatar
Yes, they are working. That's the mystery. All the lights the manual sez to check are working.
Old Oct 22, 2010 | 06:02 PM
MI1XFIRE's Avatar
Did this occur after HID or LED install?
Old Oct 22, 2010 | 09:56 PM
Pacemaker's Avatar
No sir. I've not messed with my car in any way, except for a MB air box replacing the stock air box. Nothing electrical. Thanks for asking.
Old Oct 22, 2010 | 10:25 PM
According to the shop manual it could be the 'Bulb Out Circuit ' itself and it shows a procedure to check the circuit.
If you have the inclination it may be a worthwhile thing to do.
Old Oct 23, 2010 | 04:47 AM
04 sapphire's Avatar
Hi chek u r brake light mine vas doing the same everything worked
pass brake light was @ fault
Old Oct 23, 2010 | 04:55 AM
robby363's Avatar
Did you check those 2 little parking lights in the top corner of the headlights.
Old Oct 23, 2010 | 07:46 AM
it is usually 1 of the license plate lights....
Old Oct 23, 2010 | 07:47 AM
Pacemaker's Avatar
I'll look that up and follow it as best as I can. Thanks for the help!
Old Oct 23, 2010 | 07:49 AM
Pacemaker's Avatar
Yes, sir. My wife and I both took turns looking everywhere there is supposed to be a light source, and they are all bright and smiling! Thanks for your idea. Keep 'em coming!
Old Oct 23, 2010 | 07:55 AM
Pacemaker's Avatar
Thank you for that info. My wife checked while I pressed the brake several times...the brake light is shining with every stomp. Thanks again! I'm going to take a break from the search to go to a party on a house boat in the Tennessee River here in Knoxville while Univ. of TN. (probably) get's their _____ handed to them by Alabama. Nothing smellier than dead mule..
Old Oct 23, 2010 | 09:18 AM
Joliet John's Avatar
Oh, I don't know about that. A dead skunk can be way up there on the smelly scale.
Old Oct 24, 2010 | 09:07 PM
rekcah's Avatar
Check the side markers.
also are you sure it's the bulb out indicator and not the tpms indicator?
Old Oct 25, 2010 | 06:45 AM
Pacemaker's Avatar
PROBLEM IDENTIFIED! Person in the church parking lot stopped us and said our driver side brake light was "flickering" on and off. Erratic, but at least it solves one problem. NOW...how do I change the bulb? Anyone got a sticky or a repair manual handy??
Old Oct 25, 2010 | 10:17 AM
If it is a coupe, there is a roughly 8" by 10" piece in the hatch that is directly behind the lights that will reveal thei bulbs once removed, very easy fix ahead.
Old Oct 25, 2010 | 12:24 PM
Pacemaker's Avatar
Default Got that dash light prob. solved! Thanx!
Got 'er Done!! Many thanks to all who advised me, great job!
Old Apr 20, 2011 | 07:34 PM
cszkalak's Avatar
Hello, I have two left hands, meaning I am a totally non-mechanical person. I have a rear break light burned out. How to change the bulb is the mystery I am facing. Mechanic said $185, (is this a major rip?) so I intend to learn how to do it myself.
Thanks for helping.
Old Apr 20, 2011 | 08:16 PM
MikeR's Avatar
There is a little panel/cover in the back, right and left side, that just pops off and give you access to the tail light assy. Twist out the bulb, install new, twist back in and replace the cover. Have a beer....
If you cant access it well enough that way... the whole black side piece can also be taken out pretty easily... just held in with about 6 of those little black push lock things... (it may be easy to me because I have done it several times. Your view may be different.... )
Old Apr 21, 2011 | 05:08 PM
TomStratRT's Avatar
That guy should be arrested. $2 bulb, 2 minute fix.
