Exhaust Options??? Not TOO loud?
Old Nov 10, 2010 | 06:13 PM
XfireBlake's Avatar
Default Exhaust Options??? Not TOO loud?
I have an SRT with NW intake, C3 pulley, and inmotion tune. I want more power/ airflow, but with minimal droning noise. I want a little more noise but not LOUD! What is the best option? I lean towards just deleting the resonator and keep factory muffler, Opinions?!?!?!
Old Nov 10, 2010 | 06:22 PM
bmorgan's Avatar
Default Re: Exhaust Options???? Not TOO loud?
If you are searching for more power, you will not find it with a muffler or catback. The bottleneck with the exhaust system is the exhaust manifold. There are no headers available for the Crossfire. This is the only option that I am aware of presently that will give you any additional HP. NeedsWings SRT6 Cutout downpipes
Old Nov 10, 2010 | 06:24 PM
Jason_HBC's Avatar
The Ansa seems to have been the most popular option to minimize the "droan." Quite a few of the members have done the Magnaflow Cat Back and I believe the SRT-6 is a different set up than the NA for the Magnaflow. The key is several people complained that it was too loud between 2000-2500 under a steady throttle while others enjoy the sound. I believe there are clips of the Magnaflow posted on you tube.
Gary, has the ANSA as well as several other members.
Magnaflow in my opinion has a throaty racy sound, while the ANSA has a more euro sound.
The last and most expensive option is the Borla. On the Crossfire the performance gain is minimal and its more of tone change.
Old Nov 10, 2010 | 06:40 PM
tighed1's Avatar
My roadster has the muffler cut out. LOVE the sound. No drone, not loud, sounds GREAT when you get on it, no parts to buy. Just fabricate a "Y" pipe to keep the original tail pipe pieces.
Old Nov 10, 2010 | 06:46 PM
bmorgan's Avatar
Did you remove the resonator as well?
Old Nov 10, 2010 | 07:17 PM
Voyager's Avatar
soooo you removed the muffler but kept the resonator tighted?
Old Nov 10, 2010 | 07:28 PM
tighed1's Avatar
Well I didn't do it. The previous owner did. He removed only the muffler.
Unfortunately the Y pipe he made had a steep angle on it and when you mashed the gas it would whistle. So I made a new Y pipe with a smoother angle on it and it sounds great!
When I dyno'd my cars people were more impressed with the roadster because of the way it sounded than they were with the coupe that turned out more HP and torque!
Has an exoctic sports car kinda sound.
Old Nov 10, 2010 | 09:58 PM
Squirrel Crusher's Avatar
Default Re: Exhaust Options??? Not TOO loud?
I'm considering going with a 4 port Mega-Oval muffler from WWW.stainless-specialties.com Was checking out their mufflers construction at Charlotte Motor Speedway. Sounds deep, mellow and not overly loud on a V-8 with their single 4 port design. Any muffler will be louder if you install two seperate singles. Sound can sometimes be tricky coming from a 6 cylinder like ours! I would think the four port would fit well under our cars with the rear cats removed. Finish out from this muffler with true duals. They also make up a stainless dual inlet welded into a nice looking box that looks better than the porshe boxster's exhaust tip. 4-Port dual muffler> 2 1/2H X 6 1/2W X 23" LOA. Custom sizes are avaliable.. Squirrel Crusher
Old Nov 11, 2010 | 05:09 PM
XfireBlake's Avatar
so you kept the resonator but just no muffler? Interesting... I like the racey sound of the magna flow but not if it drones. your idea sounds great but how would it compare to just deleting the resonator instead? which one keeps it from sounding like a honda
Old Nov 11, 2010 | 05:22 PM
XfireBlake's Avatar
I have laid down 7.95 @90mph in the 1/8th mile with stock size sumitomo HTR Z3 tires so I just want sound to match performance
I know the downpipes are a HUGE power adder, but I would only use them once or twice per year So I'm looking for holy crap sound without being mistaken for an accord or droning. I also want the cats to pass inspection even though I currently work at a Chrysler dealer
Old Nov 11, 2010 | 05:26 PM
XfireBlake's Avatar
Does anyone have a good sound clip of the ANSA?? Do you keep the resonator or not??
Old Nov 11, 2010 | 07:16 PM
From my N/A
Ansa Hi Performance muffler Part # UN0827
Youtube links with sound clips (headphones advised)
YouTube - Ansa Muffler - 2004 Crossfire (Use Headphones)
YouTube - Ansa Muffler - Outside sound (Use Headphones)
Old Nov 11, 2010 | 08:08 PM
XfireBlake's Avatar
Thanks Gary!!
Is it enough flow for a modded SRT and does anyone have it on an SRT??
Should I leave the resonator on??
Old Nov 14, 2010 | 11:44 AM
blownnova2's Avatar
I can't find this part# in the Ansa catalog on their website. Do you have any more info on the muffler?
Old Nov 16, 2010 | 03:36 AM
sdnatlst's Avatar
Sorry guys, what would a resonator be called in england?
Where is the resonator on the Crossfire? has anyone got any clips of it removed?
would the resonator be called the Silencer box in the UK?
i know the muffler over here is called the backbox, just unsure of resonator.
cheers!
Old Nov 16, 2010 | 06:39 AM
GenoTex's Avatar
the resonator is just ahead of the muffler, coming from the back, toward the front... two pipes in/one out...
Old Nov 16, 2010 | 12:35 PM
sdnatlst's Avatar
cheers for claryfying,
any vids around or can anyone tell me what the difference makes when having the resonator taken off? a lot louder or just a bit?
cheers
Old Nov 16, 2010 | 03:27 PM
FiftyThree033's Avatar
The question still remains.
Those with an SRT and Ansa muffler.......
Did you retain the stock resonator?
Old Nov 16, 2010 | 03:28 PM
GenoTex's Avatar
sdnatlst:
I just did a resonator delete... $150... local shop.
Raises the sound up a bit at 'cruising' ... a bit more at WOT.
On a scale of 10...
if the original pre-mod level was a 5...
then it's maybe a 6 now.
if that helps.
Just enough to enhance, without being obnoxious.
Old Nov 16, 2010 | 05:06 PM
XfireBlake's Avatar
So to get to a sound level of 7 I should delete both the resonator and muffler and just run two pipes in and two pipes out of a good after market muffler? I just can't find anyone who has tried ANSA on an SRT and I need a part number since ansa doesn't make one for us. Will the universal have enough flow for the modded srt 6??
I think I will just cut both off and then tempararily clamp each one on separately and see which sounds better alone
Thanks for all the inputs guys!!!
