P2098 Code?
Old Nov 14, 2010 | 01:32 AM
stvbrtn's Avatar
Default P2098 Code?
I am getting a Check Engine light with a P2098 code. Does anyone really know what this is?
Old Nov 14, 2010 | 04:15 AM
MJPowers's Avatar
Default Re: P2098 Code?
Post Catylist Fuel Trim too lean Bank 2
Old Nov 14, 2010 | 05:55 AM
stvbrtn's Avatar
Is that a post catalyst oxygen sensor? what would cause the Fuel to be lean? MAF, Sensor failure? I know the title of the code.
Old Nov 14, 2010 | 07:00 AM
LantanaTX's Avatar
Here is some info:
https://www.crossfireforum.org/forum...ode-p2098.html
Old Nov 14, 2010 | 10:16 AM
Rather than wait for an answer, just typing 'p2098' into the search feature would have got you. https://www.crossfireforum.org/forum...tml#post505313
Use search and you will learn a lot much faster than asking questions all the time.
Old May 24, 2011 | 05:16 PM
joejones's Avatar
I have a P2098 code. The car is making a loud noise as if there is a crack/leak/loose area in the exhaust before it gets to the muffler. I took it to a mechanic (they do Mercedes work) and they told me that I need to take it to a dealer. Now my question is - Chrysler dealer or Mercedes?
Old May 24, 2011 | 06:52 PM
grip grip's Avatar
Sounds you have a bad header gasket. You own a Chrysler, so take it to Chrysler.
Old May 24, 2011 | 07:24 PM
joejones's Avatar
Thank you Anthony. Would a muffler shop be able to do this?
Old May 24, 2011 | 07:28 PM
grip grip's Avatar
I wouldn't trust one to do the work and most won't. You should take it to a trusted mechanic or Chrysler in my opinion.
Old May 24, 2011 | 07:46 PM
MikeR's Avatar
The have also been at least two(2) cases of the cat separating at the weld. This would give the same sound and effect as a bad header gasket... and give you the code.... look at the top cat on the passenger side(bank 2).....
Old May 25, 2011 | 03:22 AM
joejones's Avatar
If separated at the weld, would the fix be simple, or would it be time to consider a different exaust? I am taking it today.
96000mi
Old May 25, 2011 | 09:23 AM
MikeR's Avatar
it will require the shop to install a new one.... easy enough for them to do, just costly for you...
Old May 25, 2011 | 02:00 PM
joejones's Avatar
Not a simple fix. The cats need replacement. Costly, but not nearly as costly as the dealer fix.
Thanks to all for your help.
Old May 27, 2011 | 06:12 PM
joejones's Avatar
Driver's side cc was broken at the posterior weld.
Old May 27, 2011 | 08:15 PM
MikeR's Avatar
bummer.... that makes 3 cars........
rampntlion
21
Feb 11, 2019 08:18 AM
TOPLESS
Feb 9, 2016 11:28 AM
crossfireusa
Oct 28, 2015 12:03 AM
tritongreen
Sep 18, 2015 07:32 AM
MickeyNasty
Sep 6, 2015 08:29 PM
