Valve cover gasket on eBay - Yes/No ?
Old Dec 13, 2010 | 06:01 PM
oojacoboo's Avatar
Default Valve cover gasket on eBay - Yes/No ?
So, I was looking around for some things and stumbled upon this thing, which looks like it might be a wonder part for our troublesome valve cover gaskets. I currently have mine disassembled and getting ready to put the gasket maker on them, but I was wondering if I should hold out and put on these instead, maybe with some extra gasket maker on the bolt holes on the inside. Thoughts??
Victor Reinz Engine Valve Cover Gasket Left - eBay (item 260701615983 end time Dec-31-10 11:32:55 PST)
Old Dec 13, 2010 | 06:29 PM
Hindin's Avatar
Default Re: Valve cover gasket on eBay - Yes/No ?
That in fact does appear to be a valve cover gasket that should work on our cars. However, keep in mind that some of us (pointing no fingers) confuse the breather covers with the term valve covers. The breather covers sit on top of the valve covers and are what is most prone to leak/seep. It's my understanding that gaskets are not available nor were they factory produced for the breather covers and therefore require the use of a gasket maker type product. As a side note NAPA sells a product called "The Right Stuff" that most shops are now using with great success, albeit a bit on the pricey side.
Old Dec 13, 2010 | 06:33 PM
oojacoboo's Avatar
Ah, I gotcha Hindin... So this is actually the gasket that goes under the valve cover that fits onto the block and not the breather covers that I have removed and have gasket maker for...? That makes more sense...
P.S. - I have the Permatex Ultra Black that everyone seemed to be recommending on here. Should be good with that, no?
Old Dec 13, 2010 | 06:51 PM
Hindin's Avatar
There is more then one type of Permatex Ultra Black, make sure it's the one that says "gasket maker". If you have it on hand I'd go with it. Make sure you let it cure for the set amount of time and be careful with those little hex screw that are located near the center part of the breather covers. I believe 2 on the right side and three on the left cover. They're made out of soft aluminum and are prone to strip/break if to much torque is exerted. Good luck, let us know how it works out.
Old Dec 13, 2010 | 06:53 PM
I did mine a moth go and so far so good. Just be sure to let it cure for a full 24 hours before driving.
Old Dec 13, 2010 | 06:55 PM
oojacoboo's Avatar
Thanks guys, yea, I know about the over torquing and the cure time, I am going to let mine sit for at least 48 hrs as I am waiting on some new ignition cables for the spark plug swap I did at the same time.
btw, it is the gasket maker one. Thanks.
Old Dec 14, 2010 | 02:24 PM
Here is the set of two.
MERCEDES CLK320 E320 SLK320 OEM VALVE COVER GASKET SET - eBay (item 170373331420 end time Jan-09-11 21:18:25 PST)
RojoGTO
Feb 6, 2016 11:14 AM
MK2005
Nov 12, 2015 11:11 AM
Codyktt
Aug 25, 2015 02:48 PM
sittininthesun
Aug 24, 2015 10:47 AM
rmcdaniel12
Aug 7, 2015 01:37 PM
