mj24724 - crossfire stereo & spkrs
Old Jan 7, 2011 | 12:48 PM
mj24724's Avatar
Default mj24724 - crossfire stereo & spkrs
i`m looking to change stereo system in my 2004 crossfire,i was wondering the best way to remove & re-install all speakers fr & rr .one question whats behind me and what size spkr can fit.i would appreciate any help anyone can help thanks
Old Jan 7, 2011 | 03:26 PM
Kolme's Avatar
Default Re: mj24724-crossfire stereo&spkrs
Originally Posted by mj24724
i`m looking to change stereo system in my 2004 crossfire,i was wondering the best way to remove 7 re-install all speakers fr & rr .one question whats behind me and what size spkr can fit.i would appreciate any help anyone can help thanks
Hmm 7? Should only be 6.... In each door you have a 1" skinny tweeter and a 5 1/4 two-way... behind you there are two 6 1/2" shallow mount subwoofers...
What i did was replace my 5 1/4's with Alpine type R's. and the tweeters with JL's.... and i left those 6 1/2"s ALONE! too much work... Instead I installed a 13.5 JL Shallow mount in the trunk... Although you can choose w/e you'd like...
When you do get your door off, makes sure you unplug the speakers before ripping away the panel... you could very well regret that...
For the door panels, there is a thread somewhere on here about how to remove them, etc, just do a search... The 5 1/4 door speakers are a bit difficult to get to because of the housing that they are in.. it just takes a little patience (you'll know what i mean when you get there)... other than that, pretty basic.
The tweeters are also a pain because the bezel for them is supperrrr small, while most tweeters are not.... so you'll need to trim the bezel around the edges to fit your tweeter, and then fasten the tweeter with your favorite brand of... whatever....
IF you do decide to mess with those 6 1/2" shallow mount woofers behind you.... then goodluck! lol.. I have seen someone however take them out and replace them with 13.5 shallow mounted woofers.... Basically, anything shallowmount will fit back there depending on how much you want to cut up your car and possibly sit closer to the steering wheel... maybe some 8" shallows would be a better route? although your stock amp isnt going to handle the RMS very well.... so prepare to up your amp by adding a second somewhere.
Old Jan 7, 2011 | 04:26 PM
Kodebuster's Avatar
Kolme, are those real Rims, or not, in your Pix.
If it's not a photoshop mock up, can you post some details.
Thanx...
Old Jan 7, 2011 | 04:51 PM
Kolme's Avatar
Thanx...
read directly below my pic =P... lol if only such rims existed...
Old Jan 7, 2011 | 04:56 PM
Kodebuster's Avatar
Got it...
They did look too good to be true...lol...
mhajek18
Jun 19, 2015 11:20 AM
turboomni08
Jun 8, 2015 11:33 AM
MJPowers
Jun 8, 2015 02:34 AM
WindRestrictor
Jun 1, 2015 02:31 PM
cojoman
May 30, 2015 09:43 AM
