cigar lighter
Old Jan 12, 2011 | 11:19 AM
slarsen2's Avatar
Default cigar lighter
Just purchased 2005 crossfire roadster with 8000 florida miles on it, when I got it home I found out cigar lighter not working. 15 amp fuse ok in block 31 and light in glove compartment works. which is part of 15 amp fuse. I wanted ot use for my gps lighter that was in cigar lighter has never been used.so probably faulty since day 1. ANY SUGGESTION on what to do? looks like miserable job to replace, maybe should wire up a new 3 plug after market receptacle?
Old Jan 12, 2011 | 12:03 PM
green-ghost's Avatar
Default Re: cigar lighter
Take a simple test light to it see if youu have current. If not you will/should check the connectors behind the outlet. Yes, this means pulliing your console but there are threads on that here.
welcome to the group
Old Jan 12, 2011 | 05:48 PM
Michelle (UK)'s Avatar
On mine the previous owner has obviously had something constantly stuck in it which had pushed out the internal prongs causing it not to work. Make sure the power is off and simply stick something in to push them back out again.
Worth a try...
Old Jan 12, 2011 | 06:11 PM
bluecoupe's Avatar
making the assumption you know ignition switch must be in or past #1 position ?
Old Jan 12, 2011 | 08:38 PM
He says the lighter has never been used, but could it be that it's the lighter itself that is broken and he assumes there is no power. Stranger things have happened.
Old Jan 12, 2011 | 09:40 PM
Kane's Avatar
Banned
Worth a try...
This is likely the case. I've found that something similar to dentist pick is an excellent tool to reset the prongs, assuming of course, that the power issue is dealt with beforehand.
Old Jan 12, 2011 | 10:57 PM
slarsen2's Avatar
Smile Re: cigar lighter
Thanks fellows, I did discover that small metal strip U shaped was not making contact, I actually removed and all worked, so am leaving it out:
Old Jan 13, 2011 | 02:07 AM
XFire-GTO's Avatar
I also just bought a 2005 Limited Coupe..... push lighter in and it dosen't stay....bought a USB plug that goes into the lighter to test if it was operable..... the blue light came on.... looks like the lighter is bad. and appears never used and elemnets inside clean....... before getting the USB plug.... told my wife to stick het finger in there as a test..... she told me to go you know where (LOL)..... now if she was blond I'd probably have had to stop her (LOL).
Old Jan 31, 2011 | 06:02 AM
XFire-GTO's Avatar
Was going to order the Cigar Lighter since mine will not stay in when pushed.... needs to be physically held in.
The Chrysler parts fellow looked it up..... there were 2 option choices ($50+ and $60+). The amount covers the lighter and a couple of other parts to assure it works. Only wanted a working and matching lighter, period. That is way too much to spend on just a lighter...... so I didn't order it.
pioneer4x4
Oct 6, 2018 01:09 AM
stlas69
Sep 14, 2015 07:37 PM
mattnelson71
Jul 29, 2015 07:27 AM
mattnelson71
Jul 28, 2015 12:52 PM
Josefigue
Jul 15, 2015 04:51 PM
