Need info on backspacing or offset on the OEM wheel
Old May 3, 2004 | 01:30 PM
landho's Avatar
Default Need info on backspacing or offset on the OEM wheel
Anyone know the offset on the OEM wheels?
Old May 3, 2004 | 03:39 PM
DFWSBR's Avatar
Default
Not sure, but you could pull off one front wheel and one rear and measure it yourself.
Old May 3, 2004 | 06:19 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default
the offset would be "stamped" into the back of the rim...on the hub area.
Old May 4, 2004 | 12:02 AM
jsisabella's Avatar
Default
I copied this from one of my old posts from February:
This is from the ronalusa.com web site for the Crossfire:
Front / Rear
Wheel Size 18 x 7.5 / 19 x 9
Bolt Pattern 5 x 112 mm / 5 x 112 mm
Offset ET 35 mm / ET 35 mm
Center Bore Dim 66.5 / 66.5
Tire Size 225/40/18 / 255/35/19
Hope this helps....
Old May 4, 2004 | 02:32 PM
landho's Avatar
Default
Just what I was looking for. Same offset for front and rear...
Old Jun 16, 2004 | 12:40 PM
marvil02's Avatar
Default
Need the info.....I ran across 2 different rear wheel offset? Which is correct? Is the stock 19x9 ET22 (Ronal Web site and message board) or ET35 (Message board). I am in the process of buying after market wheel. The ET of 22 seems to be an odd offset. The most common offset is 35 – 40. With the ET of 22 it seem that one will have to buy a good size wheel spacer. :?
Some nice dish wheels for x-fire
Front: 18x7.5", 5x112, ET35, 225/40/18, 66.5
Rear: 19x9", 5x112, ET22, 255/35/19, 66.5 :?:
This message board
Front / Rear
Offset ET 35 mm / ET 35 mm :idea:
Old Jun 16, 2004 | 08:26 PM
landho's Avatar
Default
recent pics on ebay of the back of the wheels confirms that front is 35mm offset and the rear is 22mm offset. There is an auction going on right now with the pics. 12mm is about 1/2 inch.
Old Jun 24, 2004 | 12:11 PM
krooner's Avatar
Default
Originally Posted by marvil02
Need the info.....I ran across 2 different rear wheel offset? Which is correct? Is the stock 19x9 ET22 (Ronal Web site and message board) or ET35 (Message board). I am in the process of buying after market wheel. The ET of 22 seems to be an odd offset. The most common offset is 35 - 40. With the ET of 22 it seem that one will have to buy a good size wheel spacer. :?
to clear confusion buying a wheel spacer will lower the et(offset) not raise it..
PNA
Nov 12, 2020 04:44 PM
Kodebuster
Nov 5, 2020 04:06 PM
da pink
Aug 12, 2015 05:20 PM
tom2112
Jul 28, 2015 08:12 AM
pioneer4x4
Jul 21, 2015 10:35 PM
