Exhaust leak?
Old Feb 27, 2011 | 04:03 PM
TomStratRT's Avatar
Default Exhaust leak?
I just had the Magnaflow Catback installed on my Xfire yesterday (at Midas). When I was backing out of the driveway today, I got out of the car and looked underneath to see how everything looked. I noticed that there are condensation drips coming from both the bolted and clamped areas of the system.
This doesn't seem normal to me. Am I to assume that there is also exhaust fumes leaking from those areas too? I was tempted to crawl under there today and try to tighten both areas but I wanted to get everyone's advice first. I'd especially like to hear from those that have this catback installed.
Help wanted!
Old Feb 27, 2011 | 05:59 PM
maxcichon's Avatar
Default Re: Exhaust leak?
Help wanted!
Hahahahahahahaha.
I just entered this section to see if anyone had the part number for the "donut" seal for that joint! Yes, I have had a drip on startup since I had it installed. I think re-using the seal was a mistake in my case. It may swell with heat, but I don't like it.
Tom, can you help?
Old Feb 27, 2011 | 06:12 PM
bluecoupe's Avatar
I had the same condensation drip when I did the Ansa catback on the Limited. The donut seals are not a common item at the muffler shop so I got a tube of muffler cement and put some on each side of the donut, bolted it together and problem solved!
Old Feb 27, 2011 | 06:30 PM
maxcichon's Avatar
I kinda' figgered that, but I'd be willing to replace it if a new one would fix it proper-like!:
Old Feb 27, 2011 | 06:49 PM
bluecoupe's Avatar
Max, I'm with you on that but the new donut was $50+ at the dealer and the tube of cement was a couple of dollars.
Old Feb 27, 2011 | 06:53 PM
maxcichon's Avatar
$50?
OMG!
Old Feb 27, 2011 | 07:02 PM
bluecoupe's Avatar
Can you imagine and in Canadian dollars and they're worth more than US dollars these days!
Yup, I try not to buy anything at the Dealer.............I need a new red panic button for one of my remotes and the dealer told they could order me one.................$22, you can imagine what I said.
Old Feb 28, 2011 | 05:21 PM
TomStratRT's Avatar
Hahahahahahahaha.
Tom, can you help?
Is yours leaking from both the bolted and clamped ends, or just one?
Old Mar 1, 2011 | 08:46 AM
maxcichon's Avatar
So far as I can tell, just the bolted flange. That's why I need the donut part number.
Old Mar 1, 2011 | 09:38 AM
SNAKEWOLF's Avatar
Look at 2004 Parts Manual page 107 0597567AA seal exhaust
Old Mar 1, 2011 | 10:35 AM
maxcichon's Avatar
Thanks! I suppose I could have found that! I didn't know we had a parts manual on the forum. My bad, but you're good!
Old Mar 1, 2011 | 06:36 PM
TomStratRT's Avatar
Still can't find the part online anywhere.
Old Mar 2, 2011 | 07:50 AM
maxcichon's Avatar
I called my friendly local stealership. $8.32/ea.
There was only one in Atlanta, and I got it.
MB uses the very same one-check it out:
Your Parts Search Returned 1 Part(s)
Help?
Old Mar 2, 2011 | 09:49 AM
maxcichon's Avatar
Flash!
The one I just picked up from the dealer (see previous post) is identical to the old one in all respects except one:
This one is stainless steel.
I did the install on the Magnaflow catback and the one provided from Karmann was fibrous.
I thought you should know...
Old Mar 2, 2011 | 12:05 PM
bluecoupe's Avatar
That's a fantastic price! I'm gonna call the dealer again and let them know, see what they say now. I just wonder what part they were quoting me on?
Old Mar 2, 2011 | 12:13 PM
bluecoupe's Avatar
I just called the Dealer with the 0597567AA part # and I'm told that # isn't any good. Is there another # available? thanx
Old Mar 2, 2011 | 05:56 PM
TomStratRT's Avatar
Help?
Thanks for the tip! I found a MB one online and ordered it.
Did the one you installed fix your leak?
Old Mar 2, 2011 | 08:46 PM
maxcichon's Avatar
I picked it up this AM, worked all day and just now finished and e-filed my and my daughter's taxes.
Just ain't had a chance! I'll be doing it this Saturday. I'll let ya' know then, bud.
Nobody seemed to think that the material changed-has anyone seen fiber or steel when working on the exhaust?
Old Mar 2, 2011 | 09:05 PM
Your local crappy tire used to carry a wide selection of the fibre ones at one time.But that was then and this is now, but you never know.
Old Mar 4, 2011 | 01:41 PM
DANNY62's Avatar
Banned
Hello,
I think you have another problem. A broken exhaust at the tailpipe shouldn't affect the way the motor runs.
Thanks
________
aftermarket headlights
