Exhaust leak?
I just had the Magnaflow Catback installed on my Xfire yesterday (at Midas). When I was backing out of the driveway today, I got out of the car and looked underneath to see how everything looked. I noticed that there are condensation drips coming from both the bolted and clamped areas of the system.
This doesn't seem normal to me. Am I to assume that there is also exhaust fumes leaking from those areas too? I was tempted to crawl under there today and try to tighten both areas but I wanted to get everyone's advice first. I'd especially like to hear from those that have this catback installed.
Help wanted!
Help wanted!
Help wanted!
Help wanted!
I just entered this section to see if anyone had the part number for the "donut" seal for that joint! Yes, I have had a drip on startup since I had it installed. I think re-using the seal was a mistake in my case. It may swell with heat, but I don't like it.
Tom, can you help?
I had the same condensation drip when I did the Ansa catback on the Limited. The donut seals are not a common item at the muffler shop so I got a tube of muffler cement and put some on each side of the donut, bolted it together and problem solved!
Can you imagine and in Canadian dollars and they're worth more than US dollars these days!
Yup, I try not to buy anything at the Dealer.............I need a new red panic button for one of my remotes and the dealer told they could order me one.................$22, you can imagine what I said.
Hahahahahahahaha.
Tom, can you help?
Tom, can you help?
Is yours leaking from both the bolted and clamped ends, or just one?
Originally Posted by SNAKEWOLF
Look at 2004 Parts Manual page 107 0597567AA seal exhaust
I called my friendly local stealership. $8.32/ea.
There was only one in Atlanta, and I got it.
MB uses the very same one-check it out:
Your Parts Search Returned 1 Part(s)
Help?
Help?
Flash!
The one I just picked up from the dealer (see previous post) is identical to the old one in all respects except one:
This one is stainless steel.
I did the install on the Magnaflow catback and the one provided from Karmann was fibrous.
I thought you should know...
Help?
Help?
Did the one you installed fix your leak?
Thanks for the tip! I found a MB one online and ordered it.
Just ain't had a chance! I'll be doing it this Saturday. I'll let ya' know then, bud.
Nobody seemed to think that the material changed-has anyone seen fiber or steel when working on the exhaust?
I just called the Dealer with the 0597567AA part # and I'm told that # isn't any good. Is there another # available? thanx
Hello,
I think you have another problem. A broken exhaust at the tailpipe shouldn't affect the way the motor runs.
Thanks
________
aftermarket headlights
Thanks
________
