Which XM Receiver looks best asthetically in the Crossfire??
Old May 17, 2004 | 12:48 AM
xfactor70's Avatar
Default Which XM Receiver looks best asthetically in the Crossfire??
Looking into the XM Commander. Anyone have opinions on this?
I want streamlined look...no wires showing/bulky, etc..
Thanks
X
Old May 17, 2004 | 04:56 PM
qtrfoil's Avatar
Default
And a related question, are there any antennae which won't spoil the lines of the coupe? I really miss my XM, but don't want to drive with a strange growth on the car.
Rich
Old May 17, 2004 | 05:24 PM
DFWSBR's Avatar
Default
I've heard of people, in other hatch back type vehicles, mounting the antenna inside the hatch area. Perhaps you can do the same?
Old May 17, 2004 | 05:33 PM
David Burns's Avatar
Default
Or those ultra low profile sat antenna's that you could mount on your dash? Run the wire under the dash, get it up through the defrost vent area somehow?
Old May 17, 2004 | 07:22 PM
James Sonne's Avatar
Default
Check out my album
Old May 17, 2004 | 11:08 PM
Default
Originally Posted by James Sonne
Check out my album
WOW, that thing's HUMUNGOUS! Looks more like a rooftop antenna than the sleek low-profile dash mount units they sell now.
Old May 18, 2004 | 12:20 AM
Stevo's Avatar
Default
I found a tiny antenna for XM/sirius thats about the size of a quarter. I don't know who makes it, but it was around $30-35.. I am looking into a sirius recv. Found a pretty nice looking kenwood that retailed for about $300. The silver matched perfectly to the center area's silver color... But if you want XM, I guess it doesn't help ya
Old May 19, 2004 | 10:05 AM
Default
It's a first generation TERK satellite antenna. But the point is that reception is still great.
Sirius is better than XM in every way. HUGELY better reception (3 satellites as opposed to 1), ZERO commercials on ALL music stations (as opposed to 2+ minutes of commercials per hour on XM), better selection of channels, more mainstream stations (FOX News, Discovery Channel, E!, ESPN), better talk radio stations, more support from car manufacturers.
Sirius rocks, forget about XM.
Old Jun 3, 2004 | 12:30 PM
qtrfoil's Avatar
Default
Different strokes.. but I've been happy with XM for quite some time, have had no need for manufacturer support, good coverage from the TWO satellites plus local FM retrans, get all the channels discussed above. Most important, the traffic stations available in a number of large markets are HUGE for those who'd rather drive than sit. Wouldn't be surprised if Sirius has/will have similar, though the traditional broadcasters are hitting Congress hard to legislate away the ability of satellite broadcasters to offer local programming. See here for one view on the issue: http://grassroots.xmradio.com
Old Jun 3, 2004 | 01:21 PM
Default
Yes, Sirius offers the same, and in the near future Sirius is offering navigation advice based on your location. You tune into a specific channel and based on your location it will advise you about traffic and construction ahead of you and suggest alternate routes.
And Sirius has terrestrial repeaters as well. I can put my Sirius antenna in my trunk driving through Orlando and still get perfect signal. It's not FM range, either, it's the 2.3GHz frequency, same as the satellite signal, so it's the same quality.
Old Jun 3, 2004 | 05:02 PM
kergoth's Avatar
Default
XM has terrestrial repeaters as well. I'd really recommend researching both systems before shamelessly evangelizing one or the other.
Old Jun 4, 2004 | 08:45 AM
Default
I did research both. Quatrofoil above me mentioned the FM repeaters on XM, so I mentioned that Sirius had the same.
I researched both networks for an entire year before making my decision to go with Sirius. Sirius seemed like and still does seem like the better option.
Old Jul 22, 2004 | 11:34 AM
sandmanqm's Avatar
Default Commander Works Great
X,
I have had the Commander for a little over 6 months now and have had no problems with it at all.
I purchased it at Circuit City in Fayetteville, NC and had them do the install. My X-Fire was the first one they had worked on and they were very sensitive about maintaining a clean look inside the cockpit.
They mounted the head unit just above where my right knee is on the lower dash. It's out of the way, which was the main issue for me. The micro-antenna is mounted just to the left of the center spine on the dash right up against the windshield.
No visible wires and everything works great. There is some static at different times of the day, probably because of the satellite LOS issues, but it quickly goes away.
I use the mini-remote control to do all the station changes, etc., so I'm not trying to look around the steering wheel. Once you get used to the stations you like, you won't have any problem with changing the station while driving.
Dont' have any pictures to share, but can take some and send them to you if you are interested.
Hope this helps.
Chris
SRT SIX
Jun 22, 2015 05:37 PM
MJPowers
Jun 8, 2015 02:34 AM
RED DOG
May 29, 2015 07:02 PM
prowler39
Apr 3, 2006 11:15 PM
prowler39
Jul 28, 2003 10:47 AM
