Noise from under car
Old May 2, 2011 | 08:37 AM
sprung100's Avatar
Default Noise from under car
Looking for some help...
Just a day ago I noticed my 2006 Roadster is making a kind of rattling noise coming from under the car (like metal clunking against metal)
It only seems to be when i'm moving at low speeds but continues for a few minutes if i pull over and rev the engine.
I have checked all the heat shields under the car and all are attached solidly.
As far as i can check without getting it up on the ramp the exhaust also seems to be attached at all points and solid.
I know this might be a long shot but was wondering if any you guys had a clue what it might be.
Old May 2, 2011 | 01:41 PM
muskrat's Avatar
Default Re: Noise from under car
Heat shield? Or if unlucky like me cat Hope to change mine tomorrow
Old May 2, 2011 | 01:53 PM
sprung100's Avatar
Heat shield?
The piece of metal between the exhaust and body to stop the heat transferring. Think that's what it's called. Lol
How would I know if the CAT was gone?
Old May 2, 2011 | 02:04 PM
muskrat's Avatar
I put mine on the ramp at work with the engine running - sounds like loose stones in a steel pipe, which I guess isn't far off. Its been doing it since last year on and off but got worse to the point of being embarrassing . Passed the mot ok here in the uk but I couldn't live with it any more. Just got to find out the scrap value of the old one now to attempt to recoup some of the £200 it cost (comes in 2 parts one with 3 cats and one with 1 . Needless to say it was the dearer one
Sorry just noticed where you are so you know all about MOT's!
Old May 2, 2011 | 02:38 PM
sprung100's Avatar
Hi thnx for your help.
It sounds exactly like stones in a steel pipe :-(
Was it £200 for both CATS or was that just one?
How much do you think the scrap value of the old one is?
Old May 2, 2011 | 03:57 PM
muskrat's Avatar
200 for the part with 3 cats. I got it from these people
Approved Petrol Catalyst - Click Car Parts Limited
If I get a price for the scrap bit I'll let you know, but there seems to be a lot of variation. I'm hoping the other bit will last a bit longer
Old May 3, 2011 | 12:45 PM
muskrat's Avatar
fitted the new one today - pretty easy . I've never done one before and the only hold up was cutting old bolts off (make sure you get a fitting kit with a new one). Hadn't realised how noisy the car had got - much quieter now. Just got to get some scrap money in for the old one now. One thing of interest the new one has only 2 cats instead of 3. They've joined the rear 2 together but it all fitted easily
Old May 4, 2011 | 01:54 PM
sprung100's Avatar
Got the car up on the ramp today.
Found out it is just a bracket that is attached to the exhaust that has split. Just needs to be welded - *see attached pic
Thank god......
Cost me a packet of cigarettes, lol
Old May 4, 2011 | 02:00 PM
muskrat's Avatar
I broke the same bracket off the old exhaust removing it! Bit of luck for you anyway
Old May 6, 2011 | 11:33 AM
sprung100's Avatar
2 minutes of welding and that's it all fixed.
Thank god was just a small thing
mhajek18
Dec 30, 2015 03:40 PM
frankthetank81
Dec 6, 2015 06:25 PM
vinnys
Jun 29, 2015 09:33 PM
jimbo257
18
Sep 24, 2005 09:03 PM
denc
Aug 17, 2003 01:17 AM
