How to replace the orange head light on the side
Old May 10, 2011 | 08:29 PM
nickwe21's Avatar
Default How to replace the orange head light on the side
Hey guys!
Excuse my explanation of that light The orange light on the side of the crossfire next to the tail lights isn't working on one side. How do I reach that best in order to replace it?
Thanks for the help once again!
Old May 10, 2011 | 08:40 PM
Default Re: How to replace the orange head light on the side
If I am reading your post right, you have orange side markers in rear? If so, by shifting the light forwards or backwards, the entire assy will pop out. Then you can twist the socket to get to the bulb. Common bulb for that light is 194.
EDIT: After reading this again, maybe you are talking about the turn signal bulb?
Old May 10, 2011 | 09:21 PM
nickwe21's Avatar
I'm talking about this guy
Old May 10, 2011 | 09:29 PM
That lens will pop out by shifting it forward or backward (dont recall exactly) and gently prying outward. A plastic type screwdriver device would work perfect without fear of scratching the paint. Once you pop the lens out, you will see the socket attahed to the lens. Twist.
Old May 10, 2011 | 09:31 PM
bmorgan's Avatar
use a plastic pry tool from the front side to gently pry it out. It is just a spring clip holding it in.
Old May 10, 2011 | 09:48 PM
nickwe21's Avatar
THanks, I will give that a shot in the morning!
2004_
Jul 9, 2025 12:39 AM
Kodebuster
Nov 5, 2020 04:06 PM
Roty135
17
Oct 11, 2018 10:11 AM
shawnwatson9493
Jul 9, 2015 11:47 PM
Blackout317
Jul 7, 2015 08:38 PM
