Horizontal Headlight adjustment?
Old May 12, 2011 | 08:59 PM
Default Horizontal Headlight adjustment?
I have read thru the threads and all I can find is that the horizontal adjustment can not be made. I can find nothing in the service manual about the adjustments. Each headlight has two adjustments as shown in the pics, but I can not figure out how to make it move, like it is locked. Is there a tool in the Crossfire Toolbox for this application?
I have not installed these lights yet, but would like to know how the adjustment works if needed once installed.
Thanks, James
Old May 12, 2011 | 09:39 PM
Default Re: Horizontal Headlight adjustment?
Thanks, James
I'll hazard a guess on this.
My headlight unit does not expose the bevel gear that yours shows as it is totally enclosed.
I would guess that the the top hole is totally exposed by removing that plug in it and a Torx bit is used to turn the bevel gears.
I suspect the plug is put in to deter tampering once the unit has been preset at the factory for left and right hand drive car set ups.
A screw could possibly be screwed into the plug and the plug pulled out unless it is glued in place.
I see no other reason for the bevel shown unless there is a matching gear not shown in the picture. If you look inside can you see the other gear?
Old May 12, 2011 | 09:49 PM
One gear on each headlight is open to view. The other one is closed.
Old May 12, 2011 | 10:01 PM
That must be the outboard ones you can barely see then.
But is there a second gear to be seen?
If you cannot see one gear then something like I described must do the turning.
I guess......
Or does the top outer ring come off, it being a lock of some form?
Old May 12, 2011 | 10:24 PM
And the rest of the story...
Old May 13, 2011 | 07:52 AM
So I got it correct then.
Sometimes these old codgers are smarter than you'd guess.
Old Jul 26, 2012 | 04:24 PM
maxcichon's Avatar
Or we guess better than others are smart?
Old Jul 29, 2020 | 02:21 PM
millenia's Avatar
Do you know what size the ezout is?
Old Jul 29, 2020 | 04:59 PM
KDW4Him's Avatar
I just used needle nose pliers to grab the upper lip to remove the cover. A tiny flat blade to wiggle it loose also worked.
Old Jul 29, 2020 | 05:58 PM
James1549 made a post or thread on the subject some time back, I have forgotten the details though.
Edit
Oops! It was this thread he started sorry, but I did remember it 9 years later though.
As to the size just measure the hole an find an screw extractor or something that will bite. A screw extractor with a large taper may bottom out to soon.
smfrycruzr
Jul 17, 2023 05:33 PM
Franc Rauscher
May 9, 2016 12:04 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
atdavis2
Sep 21, 2015 01:25 PM
RacerXofFL
Sep 15, 2015 05:00 PM
