removing rear emblems
Old May 28, 2011 | 02:41 AM
Boston_Bound7's Avatar
Question removing rear emblems
Has anyone removed their Chrysler or C-R-O-S-S-F-I-R-E emblems? If so are they held on with a glue or are there holes left once removed?
Old May 28, 2011 | 05:02 AM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: removing rear emblems
~ they are simply held on with double side tape from the factory. if removed no holes are present.
simple heat the plastic letters with a blow dryer and slide a piece of fishing line beneath the edge and slide the line back in forth until the emblem releases... do not pull or pry on the emblems when removing... let the fishing line to the complete job. use an adhesive remover such as goo gone applied on a micro fiber towel to remove any remaining adhesive. once complete... polish the area with a quality product and then wax... welcome to the clean look!
Old May 28, 2011 | 07:14 AM
if not fishing line....floss will work as well....giving you that "clean" look, no tarter..
Old May 28, 2011 | 07:49 AM
Erzer's Avatar
Originally Posted by oledoc2u
if not fishing line....flose will work as well....giving you that "clean" look, no tarter..
What, no minty taste
Old May 28, 2011 | 02:15 PM
Thank you!!
Old Jun 2, 2011 | 02:35 PM
Goldwing's Avatar
Make sure you really want them gone because a new set is not cheap. The original owner of my SRT6 debadged the CROSSFIRE and the SRT6 and oem prices are almost $100/each.
PNA
Nov 12, 2020 04:44 PM
rocketrage
Oct 7, 2015 05:00 PM
tom2112
Jul 28, 2015 08:12 AM
MissSilky
Jul 22, 2015 04:28 AM
axnguyen
Jul 21, 2015 11:41 AM
