Infinity problem
Old Jun 2, 2011 | 10:32 PM
GTR's Avatar
GTR
Default Infinity problem
Hi guys,
I have crossfire 04 and standart Infinity onboard.
I did reset of the ecu, now I see only blinking logo of Chrysler on it.
Somebody knows how to fix it? I assume it is blocked?
Is it possible to unblock it somehow, the problem is that I don't know the code.
thanks in advance
Old Jun 3, 2011 | 06:10 AM
bigblock427's Avatar
Default Re: Infinity problem
The infinity radio has no code protection.
Only the radio with navigation has a code protection.
Old Jun 3, 2011 | 11:19 AM
Kodebuster's Avatar
Bigblock, some info from one of your previous posts on this subject:
Navi with Infinity badge (made by Becker) - needs a code
Radio with Infinity badge (made by Becker) - doesn't need a code
Blackline radio with Infinity badge and black ***** (made by Becker) - doesn't need a code
Silverline radio (made by Alpine) - doesn't need a code
So I'm assuming that those Models that have Code, would also be reset if the Battery leads were disconnected...???
Interesting that an ECU reset has the same effect.
I'm guessing without the code...you' screwed...!!!
Old Jul 6, 2011 | 06:43 PM
CF448's Avatar
Hi,
I have a similar problem. I disconnected the battery and now every now and then when I try to turn the radio on I only get the "chrysler" display without any sound and none of the buttons are functional. It happened again today and I checked the fuses (5 & 8) and they look ok. Then I tried the radio again and it worked. We'll see what happens in the next few days.
Let me know if you resolve your problem.
Old Jul 6, 2011 | 07:00 PM
bluecoupe's Avatar
I have Infinity with nav in both cars (Becker traffic pro) and have removed them multiple times. They do not require a code.....simply plug and play!
Old Jul 6, 2011 | 08:30 PM
PNA's Avatar
PNA
This happens to these radios sometimes even if you haven't reset anything. It's gremlins. I usually just shut off the car, pull the key and put it back in and start it up. Thus far it has worked..... but if it becomes constant, it may be better to just pull it and get a new aftermarket radio.
tcar32909
Aug 1, 2024 02:41 PM
usprb1976
Apr 4, 2024 04:57 PM
jimf
Oct 10, 2015 10:22 AM
Abaton6
Sep 24, 2015 10:14 PM
Den656
Sep 23, 2015 12:27 PM
