Roadster roof rubbing strip
Old Jun 10, 2011 | 08:10 PM
MK INDY's Avatar
Default Roadster roof rubbing strip
I removed the rubbing strip today as it was creased and in poor condition, I was going to fit a new one, but I like the clean look of not having one at all, so I am going to leave it like this
Uploaded with ImageShack.us
Old Jun 10, 2011 | 08:32 PM
Default Re: Roadster roof rubbing strip
What's going to do the rubbing now? The paint?
Old Jun 10, 2011 | 09:14 PM
I wonder if someone could die-cut a clear vinyl to go where the black strip was? Like the clear vinyl bra. Have someone copy a new unused rubbing strip for a perfect fit pattern. James
PS - if it does rub into the paint, you can always cover it over with a new one.
Old Jun 10, 2011 | 09:27 PM
bmorgan's Avatar
I have had mine off for more than a year now with no adverse effects. I do not have a single mark in the paint from the top rubbing. The top actually has a padded rubber piece that sits on the paint. I believe Doc has had his off for even longer than me with no problems. Along with debadging, it makes detailing much easier.
Old Jun 11, 2011 | 07:01 AM
crossfirefrank's Avatar
I would like to remove mine. Tired of looking at the faded strip. What's the best way to remove it.
Old Jun 11, 2011 | 07:23 AM
MK INDY's Avatar
Its good to know that you and Doc have not had any problems with marks on the paint work, I think so long as you keep a good coat of wax polish on there, and keep the hood rubber seal clean it should be fine. When I drive mine I always have the hood down anyway, I think also the 350Z roadsters don't have a rubbing strip either? so I can't see a problem long term, but if I do, I can always refit the strip, so there's nothing to loose by giving it a try
Old Jun 11, 2011 | 07:37 AM
MK INDY's Avatar
It was alot easier than I thought it was going to be, I left the car out in the hot sun for a hour with the roof down, this heated the strip up, I then just peeled it off, it left a couple of patches of adhesive here and there which I removed with a bit of white spirit on a micro fibre cloth just rubbing gently, I then finished it off with a good coat of Autoglym resin wax polish
velociabstract
28
Oct 28, 2015 12:46 PM
gblack32
Sep 30, 2015 01:13 AM
mobilefitt
Jul 28, 2015 03:45 PM
mike28117
Jul 17, 2015 01:59 PM
ardenian
Jul 9, 2015 02:08 PM
