2004 XF dies at operating temp - Code P0412
Old Jul 27, 2011 | 07:16 PM
Billjhnson's Avatar
Default 2004 XF dies at operating temp - Code P0412
Hello,
Hope I have the correct thread, new to the site. I have a 2004 XF that once it reaches operating temp and is idling the car dies. Started out to being intermittant then proceeded to get worse with no hard fault registered (i.e., service Engine light would come and go). Now the car doesn't want to start until there is a significant lowering in the engine temp. Have received a constant Service light with P0412 code. Have been reading a number of posts with this issue and all point at the Relay Control board, I have pulled the Relay Board and have done a visual inspection and all solder joints look good and all the relays look good i.e., no pitting or corrosion. Started the car today and let run heard the Air pump running for a few minutes then shut off, car continued to run, then when the engine was just about at operating temp I heard the air pump kick on for just a second or two and shut off, about a minute later the engine died and would not start. Anyone have any feed back on this. Just dont want to spend money on the Relay board to find out it isn't that.
Old Jul 27, 2011 | 09:37 PM
tighed1's Avatar
Default Re: 2004 XF dies at operating temp - Code P0412
Yo Bill.
Redo the three joints pointed out in the RCM thread.
It's free and might get you back on the road.
Old Jul 28, 2011 | 05:10 PM
Billjhnson's Avatar
Hey there tighd1 on,
Thanks for the info, I have pulled the RCM thread that were talking about and found some photos showing the RCM and 3 solder joints in the upper left corner of the board. When I inspected the board i saw no solder joint that looked even close to those, so I went out and bought myself a magnafying glass, my eyes are getting old and tired..ha. I do have a couple test that I want to run on the switchover soloenoid that are listed in the service manual for P0412 basically step 3 and 4, since I dont have a scan tool thought I would try that test. But definitly gonna look the board over better. Thanks so much will let you know what I find out.
Oh by the way since owning the vehicle this is the first problem, no fuses have ever been replace, which brings me tomy question in the RCM there is a fuse block, everything I see is a 15 amp plus the 40 amp. on my RCM there is a 20 amp fuse in location 3 labeled Engine Control 1.
Thanks again
Old Jul 28, 2011 | 05:51 PM
Thanks again
This photo shows the fuse layout, it is the same is this spare one and the one in the car. Maybe no help to you but ...
Old Jul 28, 2011 | 08:42 PM
Billjhnson's Avatar
Your Photo looks Identical to my RCM and the one labeled #3 in your photo is the one in question. Pulled the fuse out and there are contacts inside the mounting area.
Have looked at the solder joints under magnafying glass but cant tell taking it to work and going to the lab and put under a microscope that we have for checking these things out. I will say they do look a little ruff, and the resistor joints dont look to great, but cant tell if they are loosing contact or not.
Old Jul 28, 2011 | 09:42 PM
Hey Bill....resolder the 3 joints....I won't say if this has happened once it has happened a thousand times...but it has happened at least 20 times....
Old Jul 29, 2011 | 05:33 PM
Billjhnson's Avatar
Thumbs up Re: 2004 XF dies at operating temp - Code P0412
Hey Everyone,
I want to thank everyone for all the help. I took the RCM to work and re-soldered the joints and few others at the same tiime. Put the RCM in the car and the problem has gone away. You guys are the best!!!!!!!!!
Thanks so much, and the little woman thankls you since it is her car, nd she has had to drive the truck while I rode the motorcycle to work. Cant thank you all enough.
Old Jul 29, 2011 | 05:50 PM
Hey Everyone,
Thanks are not required ......... send money instead.
Old Jul 30, 2011 | 06:25 AM
Billjhnson's Avatar
I spoke to soon, took the car out last nite and it has starterd doing it again. Had to have it towed back home.
waldig
Jul 31, 2017 09:46 AM
Snake Eyes
Sep 28, 2015 08:55 PM
waldig
Sep 2, 2015 11:02 AM
umpqua rafter
Aug 24, 2015 09:06 AM
cx24724
Jul 12, 2015 11:57 AM
